Motorswap vs. motorbuild for INTEGRA TURBO???
Old May 24, 2004 | 06:19 AM
spark plugs.
Guest
Posts: n/a
Default Motorswap vs. motorbuild for INTEGRA TURBO???
Hey guys,
i have a 1995 integra LS with a t3/t4 turbo.
I've noticed that the rings are leaking and i'm getting a shitload of blow by. I'm thinking if i should go with a DC GS-R (B18c1) motor or just rebuild the LS...i have about $5500 to play with. Any suggestions? TIA.
Old May 24, 2004 | 06:28 AM
Honda Hick's Avatar
Default Re: Motorswap vs. motorbuild for INTEGRA TURBO??? (troublecodes)
I would rebuild the B18B motor. You'll be great for the long run if you sleeve and fully build the motor. If you get a B18C it'll just be a matter of time til the rings landings crack. Plus, you never know what the condition of the motor is in when you buy a used mootor. You might end up needing to rebuild that then and it might be over your budget.
Old May 24, 2004 | 08:17 AM
RyanEJ8's Avatar
I agree, rebuild the motor you have. You never know what you are getting when you buy a used motor.
Old May 24, 2004 | 08:22 AM
Pawwalski's Avatar
Definately rebuild.
spark plugs.
Guest
Posts: n/a
Default Re: Motorswap vs. motorbuild for INTEGRA TURBO??? (RyanCivic2000)
kno anywhere i can get buildup suggestions?
Old May 24, 2004 | 08:25 AM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by troublecodes &raquo;</TD></TR><TR><TD CLASS="quote">kno anywhere i can get buildup suggestions?</TD></TR></TABLE>
I would search around here and look over other people's setups. That's the best way to get ideas.
Old May 24, 2004 | 11:15 AM
Rod.'s Avatar
i would go with earl
Old May 24, 2004 | 11:59 AM
spark plugs.
Guest
Posts: n/a
Default Re: Motorswap vs. motorbuild for INTEGRA TURBO??? (redturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">
i would go with earl</TD></TR></TABLE>
the mod?
Old May 24, 2004 | 12:01 PM
5STAR3's Avatar
the mod?</TD></TR></TABLE>
yea
Old May 24, 2004 | 12:04 PM
spark plugs.
Guest
Posts: n/a
Default Re: Motorswap vs. motorbuild for INTEGRA TURBO??? (envision2teg)
thanx!
1316130057's Avatar
You'd end up waaaaaay better off by race building that B18b for the same cost of the stock B18C1 which'll just blow eventually.
Old May 24, 2004 | 12:08 PM
B18C1CYA's Avatar
send the block to earl and get benson sleeves and do a ls/vtec turbo, i totaly agree y get somthing that is used u never know the real reson y someone sold it. plus you already know whats up with your motor
Old May 24, 2004 | 12:30 PM
spark plugs.
Guest
Posts: n/a
Default Re: Motorswap vs. motorbuild for INTEGRA TURBO??? (B18C1CYA)
thanks, i didn't even know that earl did work like that...i'll pm him right now.
Old May 24, 2004 | 01:04 PM
Honda Hick's Avatar
Here are two threads on the Benson blocks he sells:
Benson Sleeved Blocks..How they are made and why they are the best https://honda-tech.com/zerothread?id=565375
https://honda-tech.com/zerothread?id=692320
tylersteg
Jun 5, 2007 05:48 PM
billyinse
35
Jan 20, 2007 11:46 AM
fthesys
Apr 30, 2006 06:42 PM
ThaCivicAssassin
26
May 17, 2005 05:34 PM
sol_1320
Feb 26, 2004 04:27 PM
