need advice/info 14b turbo +d15b2 90 hatch
Old May 24, 2004 | 01:38 AM
7808's Avatar
Default need advice/info 14b turbo +d15b2 90 hatch
well, i got a decent 14b turbo from a 1g eclipse, 4x 450cc blue top injectors, and a drag fmic.
i think it would be, but anyone done this, is it a good turbo for this engine?
where can i get a turbo manifold for my d15b2 ? (somewhat cheap)
i know i will need to swap out my intake manifold for a mpfi.
what kind of engine managment?
how much boost can i do safely on stock internals and keep decent gas milage ?
Old May 24, 2004 | 04:22 AM
91hob20hb's Avatar
A 14b is good turbo for your motor due to it being small you will be spool up faster,When it comes to max amount of boost I would limit it to around 6-8 psi some people claim more boost is possible but with alot of tunning and excellent E.M.U like hondata.But you must consider too with more boost brings the factor of how long it will last too.Now cheap turbo manifold one from a crx/civic hf they work great and can usually be picked up for $25 but then you have to do the proper modifying to make it work right or you can find them on ebay some times already modified for around $50-100.
F.S. d15b6 motor and tranny $150+shipping
F.S.Unorthodox racing crank pulley(blue) 75shipped fits b18c1,c5 and b16
F.S. 4 stock obd1 injectors 240cc. $75shipped
Old May 24, 2004 | 05:07 AM
USDM 4G VTEC's Avatar
14B ARE GOOD
i have it and love it
the problem is that the stock wastegate is about 10 psi and u wont be able to lower it with a stock wastegate unless uhave an external one
i can do the HF to 14B adapter plate
iwouldnt run no more then 5.5 psi on that motor
u can rn the VAFC hack unless u really want more boost or get a better motor
Old May 24, 2004 | 09:16 AM
7808's Avatar
Default Re: (USDM 4G VTEC)
i figured it would be good , fast spooling smaller turbo and stuff, whats a hf manifold? how much whp would 5 psi make? im not lookin for alot. not on this engine..
Old May 24, 2004 | 10:11 AM
Default Re: (fuctup)
rule of thumb
u gain about 10hp per /psi
means extra 50 hpto whatever whp u already putting down
Old May 24, 2004 | 10:20 AM
SeanEF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fuctup &raquo;</TD></TR><TR><TD CLASS="quote">whats a hf manifold? </TD></TR></TABLE>
Exhaust manifold from an HF crx
Old May 24, 2004 | 01:47 PM
7808's Avatar
Default Re: (SeanEF)
thats what i thought, but do you guys mean by a turbo manifold for a hf crx?
arent 14b stock wastegate set at like 7psi?
Old May 24, 2004 | 07:06 PM
SeanEF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fuctup &raquo;</TD></TR><TR><TD CLASS="quote">thats what i thought, but do you guys mean by a turbo manifold for a hf crx?
You can modify an HF manifold with an adapter plate for a turbo..check out this site if you haven't already seen it
http://www.homemadeturbo.com
alot of good info on exactly what you are looking to do
Old May 27, 2004 | 10:40 PM
straggs42d15's Avatar
Default Re: need advice/info 14b turbo +d15b2 90 hatch (fuctup)
go to homemadeturbo.com they have good info for 14b turbos on d15 and ZC, minime, and d16. maybe itll help
Boost Films SFL
Sep 17, 2012 10:59 AM
EGcivic_95
Aug 10, 2011 05:55 PM
gsrcivic619
Sep 12, 2003 06:45 AM
redrex
Aug 25, 2003 06:42 PM
