diesel turbo ls civic?
Re: diesel turbo ls civic?
google civic hoslet.
it can be done. spool time depends on what turbo you have and what bods.
hoslets are a common diesel engine turbo off og the cumming/dodge pick up trucks.
Yes it can be done, lots of people have done it. That's the only turbo I use due to price and results. They are tough turbos. You can get a hx35 and BEP hot side to get better spool time. I love my holset turbo. If your only going to boost low 8-12psi get a turbo that better suited for your engine. Holset are capable of over 30 plus psi.
ok i got the turbo but...i have one issue. my old turbo manifold is to small for the turbo. like where they bolt together or the flange i should say is small on the turbo how can i fix this? cut and weld?
you can cut and weld, there soo many manifold optionss out there that i am sure you can get the correct manifold for cheap.
what motor you running?
what turbo do oyu have?
post pictures if you want serious help.
ls holset large comp h1c 12cm2 exhaust housing 20psi between 4-4500rpm. 338hp 293trq. hx35 on a gsr is a rocket for the people that don't know.
exhaust housing doesn't look to big there is a # stamped on the inside of the ex inlet what is it? There should be a tag on the comp housing of what it is. Is it t3 or t4 flange? got any pics straight at the comp housing? from the looks of it looks like a hy35 which is smaller and comes with a 9cm2 housing.
Try sticking with the common used holsets like h1c, hx35, hx40, h1e. Not all holset will have t3 flange. When sourcing a holset make sure it has a t3 /t4 housing. Makes install more pnp.
What does it say on the plate for that turbo. Should have an id number.
so does it have the 23cm ex housing? from a quick search ex houing is way to big and there isn't much interchangablitiy with other models.
lol yeah its pretty big it dont even look like it will fit under my hood, what are the most common holset turbos to get? and what are they off of?
hy35 hx35/40 h1c 90's dodge trucks. I'm gonna try a hx55 on my next setup with a aftermarket ex housing. I would look into seein is anyone makes a smaller ex housing for it.
