CEL problem getting cel 22
I am getting a cel 22 with my obdII to obdI conversion. I am using a p06 with one of kenji's conversion harness. I have a 98 d16y7 which is non vtec and the ecu is non vtec. I don't know where this cel is coming from. I had one for the iacv but I fixed that and now this one keeps on coming back. I also have a problem with the idle. The car idles fine for three or four minutes then it will stumble and almost die then go back to normal again. I am running hondata s200b/ p06 with a stock intercooled greddy kit and y8 im. Any and all help would be much appreciated.
Thanks
Thanks
Is that possible. Could it be socketed incorrectly? Could the wrong basemap cause this? What should I check inside of the ecu to see wether it is setup for vtec or not?
Problem is still here someone recommended that I check the ecu to make sure that its not chipped for vtec. What do I look for to make sure its setup for non vtec?
Michael Ancira
Jan 15, 2017 04:49 PM
