PCV VALVE
Old May 23, 2004 | 07:27 PM
xsoofreshx's Avatar
Default PCV VALVE
does the 2000 civic SI coupe have a PCV valve?
Old May 23, 2004 | 07:29 PM
mrpeabody's Avatar
Default Re: PCV VALVE (xsoofreshx)
yeah it should have one. look under the intake manifold.
Old May 23, 2004 | 07:34 PM
xsoofreshx's Avatar
thanks
Old May 23, 2004 | 07:41 PM
RedlinedVTEC's Avatar
Default Re: PCV VALVE (mrpeabody)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrpeabody &raquo;</TD></TR><TR><TD CLASS="quote">look under the intake manifold.</TD></TR></TABLE>
Incorrect. It sits on the intake manifold between the 3 and 4 runners. Close to the head.
Old May 23, 2004 | 07:46 PM
xsoofreshx's Avatar
thank you !
Old Jun 20, 2004 | 05:23 PM
xstalkrx's Avatar
Default Re: (xsoofreshx)
wtf is a pcv valve and what does it do
Old Jun 20, 2004 | 05:32 PM
Turbogixxer's Avatar
Default Re: (xstalkrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xstalkrx &raquo;</TD></TR><TR><TD CLASS="quote">wtf is a pcv valve and what does it do</TD></TR></TABLE>
It is a one way valve that (under vacuum) bleeds off the positive crank pressure back in to the intake charge (on stock figure). Positive crank pressure (If not vented) will cause your gaskets to blow out and cause the motor to run poor.
Homotor
Jan 21, 2008 10:19 PM
coupon
Dec 11, 2004 04:36 AM
..::91TEG-G2::..
Nov 16, 2004 09:50 AM
DaX
May 23, 2004 07:11 AM
b18c-93
Nov 28, 2003 04:33 PM
