What setting for turbo d16z6?
Hi, I have pretty much a stock d16z6 setup!
How many PSI should I go for? How much hp can I get? (daily driven)
Which point should I set the Vtec and Rev Limit values?
Is there anything I should have besides the list below?
Thank you for your time!
1. 94 D16z6 SOHC Vtec Engine (from a Civic Si) (70k miles)
2. 92 DX tranny w/ 95 Delsol Si Vtec Gears and final drive (40k miles)
3. 60mm Throttle body
4. Ported z6 intake manifold, ported plentum to 62mm
5. Blue NGK spark plug wires
6. Denso Irideum spark plugs
7. MSD 6al ignition
8. B&M Fuel Pressure Regulator
9. B&M Fuel Pressure Gauge
10. P28 Vtec ECU
11. Uberdata
12. Custom Turbo Manifold
13. 16g Turbo
14. oil feed line
15. oil Return Line
16. BOV
17. Walbro255 fuel pump
18. 440cc injectors
19. cold air intake
20. test pipe (no cat)
7. MSD 6al ignition
10. P28 Vtec ECU
11. Uberdata
13. 16g Turbo
14. oil feed line
15. oil Return Line
16. BOV
18. 440cc injectors
19. cold air intake
Because your question(s) are regarding your turbo setup, this thread should be have entered into the forced induction forum.
The users who post there, will be able to answer all of your questions.
And you'll be hearing more....Search first...you'll find a lot of what you're looking if you search first.
boostedcivichatchbacksi
Aug 20, 2004 04:17 PM
