d16z6 turbo...intake manifold
hey HT just a quick question...i did sum research but im getting too many different opinions...i have a d16z6 turbo running at 10psi that i drive daily. i wanted to know if i put a better intake manifold and a bigger throttle body will it make any kind of difference for everyday driving? and i do get one do i hafta have my car re-tuned?
Man U FTW
Re: d16z6 turbo...intake manifold
You could stand to see a gain from those upgrades; however, they might not be a limiting factor in your setup at the moment. If you could give us a complete run-down of your turbo setup (and engine build if it isn't stock), we will be able to make a better suggestion. Also, as with EVERY engine modification, you will need a retune....first of all, to ensure that your Air/Fuel ratios are within safe range and secondly, to optimize the parts you bought.
One more thing to consider: A stock D series can be pushed into the 220-240whp range, but they dont like putting down much more than that reliably. If you're not built, you may have issues if you decide to make more power.
ok here is my set up
D16z6
stock block
cometic headgasket
buddy club titanium internals (valves, springs, retainers etc...)
550cc injectors
new oem cam gear and timing belt
T3 turbo set up
tuned on 10psi
pushing about 200-210whp (its my daily driver btw)
D16z6
stock block
cometic headgasket
550cc injectors
T3 turbo set up
tuned on 10psi
vtec8200
02-21-2009 02:22 PM
Boricuanology
07-04-2006 04:52 AM
luelf21
10-26-2004 08:11 PM
