t3 good enough for b18b?
Old May 23, 2004 | 01:39 PM
No's Avatar
No
Default t3 good enough for b18b?
I have a chance too get a t3 turbo for 90 bucks and has just been rebuilt.Im wondering if it is sufficent for a b18b.I would like too have 200-250 hp.Not at first but after good fuel management.Is this turbo ok for this?Or should i go with the t3-t4?
Old May 23, 2004 | 01:44 PM
1316130057's Avatar
Default Re: t3 good enough for b18b? (narib2oo1)
A t3 (although you didn't specify what size) will spool like the car were NA on a b18. Transient response will be extremely linear. Sounds good to me, but you're gonna want more power eventually.
Old May 23, 2004 | 01:46 PM
No's Avatar
No
t3 turbo with a compressor AR of 42 and a turbine AR of 49(HOT SIDE
Old May 23, 2004 | 01:48 PM
No's Avatar
No
what kind of number could this put down around 7psi-10psi?
Old May 23, 2004 | 01:54 PM
1316130057's Avatar
Default Re: (narib2oo1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by narib2oo1 &raquo;</TD></TR><TR><TD CLASS="quote">what kind of number could this put down around 7psi-10psi?</TD></TR></TABLE>
I'd realistically need more precise numbers than just the boost level, but ~70-80 more HP than currently.
Old May 23, 2004 | 03:26 PM
Smooth-GSR's Avatar
Default Re: (1316130057)
I am about to run a t3 on my b18b, its not quite done but I will let you know what I put down. Its a t3 from a nissan, 63/60. Also look at other mods besides just the turbo, like fuel management.
Old May 23, 2004 | 07:18 PM
No's Avatar
No
70-80 more?Thats horrible.The t3-t4 kits can hit 230 at 9 psi or so.Maybe i wont get it.I wanted too hit at least 200 at 7 psi.Im just gonna be running a vortech fmu,tial bov,tial wastegate,greddy intercooler,bigger injectors if you think it will help.
Old May 23, 2004 | 07:30 PM
1316130057's Avatar
You said the most important part of the entire equasion...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by narib2oo1 &raquo;</TD></TR><TR><TD CLASS="quote">The t3-t4 kits can hit 230 at 9 psi or so.</TD></TR></TABLE>
Different compressor = entirely different story. Also, 230hp is 90more.
Old May 23, 2004 | 07:47 PM
No's Avatar
No
well a stock ls will put down around 120 so with 70-80 more.Thats 190-200 hp.Or were you saying the 142 hp it starts with?So 70-80 more than that?
Old May 23, 2004 | 07:58 PM
1316130057's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by narib2oo1 &raquo;</TD></TR><TR><TD CLASS="quote">well a stock ls will put down around 120 so with 70-80 more.Thats 190-200 hp.Or were you saying the 142 hp it starts with?So 70-80 more than that?</TD></TR></TABLE>
You got it. It's 70-80 + crank.
Old May 23, 2004 | 08:41 PM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by narib2oo1 &raquo;</TD></TR><TR><TD CLASS="quote">70-80 more?Thats horrible.The t3-t4 kits can hit 230 at 9 psi or so.Maybe i wont get it.I wanted too hit at least 200 at 7 psi.Im just gonna be running a vortech fmutial bv,tial wastegate,greddy intercooler,bigger injectors if you think it will help.</TD></TR></TABLE>
vortech fmu
i wouldn't go cheap on the ems,
your engine won't last
Old May 23, 2004 | 09:33 PM
b16ahybrid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1316130057 &raquo;</TD></TR><TR><TD CLASS="quote">You said the most important part of the entire equasion...
Different compressor = entirely different story. Also, 230hp is 90more.</TD></TR></TABLE>
Your comparing whp to crank hp.
230whp is roughly 265 crank hp
so roughly about 125 more hp
Old May 23, 2004 | 09:47 PM
1316130057's Avatar
Default Re: (b16ahybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16ahybrid &raquo;</TD></TR><TR><TD CLASS="quote">
Why do you think I'm confusing crank hp with wheel hp?
140 + 90 = 230
Old May 23, 2004 | 09:48 PM
playboyace35's Avatar
i have a b18b1 with a T3 "45"....at 4.5 psi, it is 180hp and 166tq to the wheels with many leaks heh.....
bov leak, manifold exhaust leak cuz one of the studs are broken.
my mods are
safc
450 dsm injectors
soo i think around 9psi i would be at 220-230, i know we have different fuel management but we should be around same number maybe.... well hopefully this helps hehe
Old May 23, 2004 | 09:55 PM
b16ahybrid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1316130057 &raquo;</TD></TR><TR><TD CLASS="quote">Why do you think I'm confusing crank hp with wheel hp?
140 + 90 = 230</TD></TR></TABLE>
Oh I don't know....
You never did say whp.
It's just been a long time since I've seen a dyno calculate flywheel hp and not wheel hp.
When most people say they want X amount of hp (230 in this case) they generally want to see that on the dyno sheet so meaning 230whp.
I'm just going on about pointless suff.
Old May 23, 2004 | 09:58 PM
XDEep's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by narib2oo1 &raquo;</TD></TR><TR><TD CLASS="quote">t3 turbo with a compressor AR of 42 and a turbine AR of 49(HOT SIDE</TD></TR></TABLE>
sounds like a 14b or a typical turbo off an audi. you should be fine for your goals, even beyond. the question is whether your block can handle it and how to do it properly.
Old May 23, 2004 | 10:08 PM
GDM Z28's Avatar
i put down 242whp with 10 psi on a turbo like this with a crushed IC pipe
Old May 23, 2004 | 10:14 PM
Default Re: (civicflnum1)
but ur t3/t4...its not realli comparable right? to a t3? ionoi correct me if im wrong cuz im not too sure hehe
Old May 23, 2004 | 10:17 PM
GDM Z28's Avatar
Default Re: (playboyace35)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by playboyace35 &raquo;</TD></TR><TR><TD CLASS="quote">but ur t3/t4...its not realli comparable right? to a t3? ionoi correct me if im wrong cuz im not too sure hehe </TD></TR></TABLE>
are you talking about me? before the t3/t04e i used a t3 just like this guy has. same exact one actually
Old May 23, 2004 | 10:24 PM
o hehe i didnt' read it fully heh
StocK LS, t3/t04e, 10.5 psi with a partial tune 265whp and 237 wtq Tuned by Dave (vtc_civic). If your in Florida and you need tuning please pm me!
i was just readin that heh sorries
Old May 23, 2004 | 10:39 PM
GDM Z28's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by playboyace35 &raquo;</TD></TR><TR><TD CLASS="quote">o hehe i didnt' read it fully heh
i was just readin that heh sorries </TD></TR></TABLE>
lol its ok man. i had the old numbers in there but i just erased them.
Old May 23, 2004 | 11:23 PM
1316130057's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">I'm just going on about pointless suff.</TD></TR></TABLE>
lol, I was starting to nod off a split second before you said that.
Hey PLayboyace, I was reading your sig and remembered when that jackass originally poseted it, lol. Good times.
Ahh.. now that this question has been answered ten times over..you know what I miss? That game Double Dragon...
Old May 24, 2004 | 05:01 AM
Johnyquest's Avatar
The t3 will work very well on the 1.8 -- remember these turbos came off mostly 2.2l cars from the factory. They still had a 'bit' of lag on those cars, but on ours it's a little worse. On my 1.6 (d) i have 3500rpms of lag. You might get away with 2500? It will be nice.
Old May 24, 2004 | 05:56 AM
No's Avatar
No
So overall a good cheap turbo too get?90 bucks.And numbers should be over 210 or so at 7 psi.Thats good for me.Thanks
Old May 24, 2004 | 08:38 AM
1316130057's Avatar
Man, WTF is your problem. Can't you see I was talking about Double Dragon?! Double...Dragon, bro.
For the 40th time, that turbo will be more than fine on our 1.8l 4cyls whos heads flow more CFM than the 2.3 liter cars that it came on. My XR4Ti when it was stock had lag for about 2200rpm and thatis with more restrictions than I care to mention. This teg will lag for no more than 2800pm.
Now.. what was the big-guys name? Shadow Master? WTF kinda power would someone named "shadow master" possibly have?!
BIG T
Apr 11, 2007 05:34 PM
Del$olB16A3
Apr 5, 2005 07:46 PM
asianspeed
Nov 30, 2004 03:17 AM
legendboy
Jun 24, 2002 11:50 PM
HuskerHybrid
Jun 4, 2002 10:03 AM
