Can't seem to find problem
Old May 23, 2004 | 12:10 PM
CivicBoi's Avatar
Default Can't seem to find problem
1990 Si Stock engine
Battery is not charging properly... I would boost it and it would start fine... drive it for about half hour to hour... then shut it off.. if I start it within 20 mins of driving it will start... but if I leave it for more than 2 hours I would need to boost the battery to get it started... I did a visual inspection of the alternator... and it looks okay.. spinning alright... I'm getting a error 20 short flashes on the ECU.. --> motor is stock...
thanks for all the help
Old May 23, 2004 | 01:37 PM
LudeEFv2.4's Avatar
My old title sucked.
Default Re: Can't seem to find problem (CivicBoi)
replace your alternator dood. tho it might spin freeley the brushes on the inside are whats f%ck3d. and don't get one from napa, use honda parts.
Old May 23, 2004 | 02:27 PM
CivicBoi's Avatar
Default Re: Can't seem to find problem (LudeEFv2.0)
thanks... 'bout the ecu error code?
Old May 23, 2004 | 04:25 PM
civickiller's Avatar
have yoru alt tested to see if its good, dont assumebeause of the code 20
Old May 24, 2004 | 12:41 PM
LudeEFv2.4's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicBoi &raquo;</TD></TR><TR><TD CLASS="quote">thanks... 'bout the ecu error code?
20 = (ELD) electric load detector
JDM_95_LS
Audio / Security / Video
May 19, 2007 07:33 AM
Sportyballade
Oct 27, 2006 05:05 AM
mugenhatch92
Aug 31, 2004 06:51 PM
PreludeSiRally
Oct 6, 2003 11:45 AM
