THrottle Pos. Sensor, it is set on the stand alone correctly, but got a CEL
Old May 23, 2004 | 11:03 AM
wade's Avatar
Default THrottle Pos. Sensor, it is set on the stand alone correctly, but got a CEL
i got a hondata, the throttle pos. sensor is dialed perfect. I know its plugged in, but last few days it has idled really low sometimes and im throwing a check engine light for the TPS. WHat is the deal?
UpDate: I used a multimeter on the middle wire to check voltage. At idle with just the key on it should read ~.45 Volts at at WOT it should read ~4.5 Volts i believe. Well wit jus the ignition on it read .40 and at WOT it would read, went to ZERO. If i would slowly turn the throttle plate from closed to open the Voltage would increase like it should, but at about 3/4 throttle @ 3.2 Volts would be the highest reading. Anything past that the Multimeter would go to Zero. So it seems from closed throttle to 3/4 throttle readings are decent and anything past 3/4 throttle does nothing on the multimeter.
Modified by wade at 12:27 PM 5/23/2004
elynen
Honda CR-V & Element
May 25, 2018 10:51 AM
dhdave2509
Engine Management and Tuning
Feb 20, 2010 08:59 PM
GSRcivicGSR
Dec 20, 2004 04:29 AM
GsRwHiTe
Mar 22, 2004 03:08 PM
98teg
Jun 4, 2002 04:25 PM
