really low compression in #4!?!? bent valve or piston rings?
Old May 23, 2004 | 09:48 AM
Yosshaa's Avatar
Default really low compression in #4!?!? bent valve or piston rings?
really low cmpression in #4!?!? bent valve or piston rings?
its a b18a, i road race it engine block has 125k on it (head was rebuilt and slapped on and has 5k on it), did a compression test came back 162-165-163-115! i thought 3 was the weak cylinder!
is it the piston rings or possibly a bent valve?! how can i tell?
Old May 23, 2004 | 10:04 AM
GeeReg's Avatar
Default Re: really low compression in #4!?!? bent valve or piston rings? (ambition)
You need to do a leakdown test to tell. Search for info on it.
Old May 23, 2004 | 10:53 AM
mmuller's Avatar
Mad Scientist
the way to really know is to do a leakdown test.
but you could check valve clearances to see if they are off on that cylinder.
put a cap of oil on that cyl. to see if #'s go up, if they do is most likely rings.
are you burning any oil?
Old May 23, 2004 | 11:55 AM
Yosshaa's Avatar
Default Re: really low compression in #4!?!? bent valve or piston rings? (mmuller)
burning a lil oil. but thats to be expected of a honda eninge wit 125k.
valve clearences are fine all the way through. leak down test should come some time this week. thanks for the replys!
H22 CB
Oct 30, 2015 05:23 PM
iBrandon
Jul 31, 2006 08:03 AM
vxturbociv
Jul 23, 2006 06:27 PM
oilguzzler
Nov 22, 2005 05:26 PM
DANG YO
Nov 24, 2003 04:26 AM
