Aluminized Steel Piping?
I am going to be using aluminized steel piping for my intercooler/charge pipes from JC Whitney. I'll be following the directions for the piping from here. http://www.cse.uconn.edu/~yele....html
Since I don't want to have to use 9 silicon hose connectors, I will be having some of it welded together. Won't the aluminum coating blow off near the welds and then rust?
It'll be fine - not the lightest and most rust resistant, but it's fine. The welds will probabably rust long before the piping anyway. My buddy painted his and all is fine.
yeah i used the aluminized piping from jc whitney...
eventually it will rust... theres nothing you can do about that..
paint it silver and it will still look metal like
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sky88 »</TD></TR><TR><TD CLASS="quote">why u guys dont use an aluminium pipe instead of aluminized steel piping</TD></TR></TABLE>
Aluminized steel is cheaper and easier to work with (cheaper to weld).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18Flip »</TD></TR><TR><TD CLASS="quote">if you dont want the welds to rust, just use stainless 308 MIG wire....works for me lol</TD></TR></TABLE>
I don't have a MIG welder, but I'll keep that in mind wherever I take the piping to be welded. Thanks.
I'd use aluminum if I had the right equipment, but I have a mig (w/o a spool gun for AL) at my disposal. So I just use what I have. I drive an accord anyway, it's not like I'm too concerned about weight
I m using the same stuff, I had Tony1 weld mine in a couple places to keep the couplers to a minimum, then I painted it with some 500vht stuff from Walmart and it looks fine.
Snafu-Si
Feb 12, 2003 12:27 PM
