Me again with da ROUGH IDLE...ARGH
Old Nov 8, 2001 | 10:13 AM
94ludesi's Avatar
New User
Default Me again with da ROUGH IDLE...ARGH
Ok...so i've basically tried everything to fix the rough idle. New rotor, cap, wires, spark plugs, cleaned out throttle body, new battery...I need suggestions...please..and how to fix it
Scenario of the problem...when the engine first starts up when itz cold it idles high and then resumes normal idle around 750 which ends up with shaking and vibrating like a hand held massager. What else could be the problem? Anything cheap I can rule out for now that i can check by myself?
Old Jun 21, 2003 | 10:06 AM
spunky424's Avatar
Default Re: Me again with da ROUGH IDLE...ARGH (94ludesi)
hey did you ever solve this problem i got the same problem with my eg hatch and gsr motor
Old Jun 21, 2003 | 10:16 AM
92SiB18C1's Avatar
Default Re: Me again with da ROUGH IDLE...ARGH (spunky424)
I don't know if it helped, but I have the same problem, just not as bad (shaking). I did change my clutch with ACT streetlite. Now my car idle perfectly. I don't know if it's really true.
Old Jun 21, 2003 | 10:48 AM
mmuller's Avatar
Mad Scientist
Default Re: Me again with da ROUGH IDLE...ARGH (92SiB18C1)
have you check engine mounts?
Old Jun 21, 2003 | 11:13 AM
preluder's Avatar
Default Re: Me again with da ROUGH IDLE...ARGH (mmuller)
check your mounts,tps sensor and idle air control valve sensors and maybe mapsensor. BUt i think its both cause of the idle thats a sensor or timing ignition problem. As for shaking im thinking motor mounts aint tight enough or may need replacing bro. check in between the mounts with a flashlight if you see it cracks or split it may be going or just a chunk of rubber that just fell off the metal part that supports it just gone.
Old Jun 21, 2003 | 11:26 AM
2k1_ITR_0736's Avatar
Default Re: Me again with da ROUGH IDLE...ARGH (preluder)
i was gonna say motor mount too.
you guys are grave diggers
MyEj1Broke
Jan 10, 2014 08:09 AM
Nisif
Nov 26, 2011 07:22 PM
BOOSTED_JDM_DB8
Feb 3, 2006 01:01 AM
dgie31
Oct 3, 2004 06:25 PM
ZColeon
Nov 16, 2001 09:02 AM
