Compression Test Results
Old May 23, 2004 | 06:52 AM
ITR RACER's Avatar
Default Compression Test Results
I have a stock 97 JDM B18C-R Motor in my hatch with Toda Spec B's. Just did a compression and got the following low numbers: 195 195 195 199.
From the search i have done, these numbers seem awfully low for a Type R motor, but are atleast consistant.
Should there be any reason for concern? If so, what can cause low compression numbers eventhough they are consistant?
Old May 23, 2004 | 08:30 AM
Warren's Avatar
Wrong-Way Wang
Default Re: Compression Test Results (ITR RACER)
It's fine.
Warren
Old May 23, 2004 | 08:31 AM
FOrSfEd's Avatar
Default Re: Compression Test Results (Warren)
Did you get those numbers at wot
Old May 24, 2004 | 08:49 AM
ITR RACER's Avatar
I did the compression test exactly as shown on the cspeed racing site.
http://www.c-speedracing.com/h...t.php
No one has any reasons why it is so low?
Old May 24, 2004 | 08:53 AM
RTW DC2R's Avatar
how many miles on the motor?
Old May 24, 2004 | 09:07 AM
Bbasso's Avatar
IF you did the test correct and the #'s are that close I would not worry about them being low.
Old May 24, 2004 | 09:28 AM
shivers's Avatar
Make sure the engine is up to opeating temp before you do the test. I didn't at first and my numbers were low. After some advice, I did the test again with the car warmed up and the numbers were right on the money.
Old May 24, 2004 | 01:45 PM
ITR RACER's Avatar
I beleive the motor had about 50k km when i purchased it, so it should be close to that now as it is a race only vehicle.
Warming the car up can make that much of a difference? That's weird...
Old May 24, 2004 | 03:09 PM
Chubz's Avatar
Default Re: (ITR RACER)
dont forget that the toda cams play into compression numbers as well, u are looking for consistency. Make sure car is at operating temp and at wot. Also if your valves need adjustement, it also plays a role in the numbers too, i gaind almost 15 psi when i adjusted my valves. I have the same motor as you, stock cams though and put down 270 across the board.
DAprojectTuRtle
May 1, 2010 02:03 PM
97civic07gsxr
17
Mar 5, 2009 12:30 AM
snowblind7x
Apr 13, 2005 08:12 PM
sdinteg
Feb 1, 2005 07:52 PM
