Car parked in gear overnight and no clutch fluid next morning?
i hardly ever leave my car in gear but i parked on a hill last night and left it in gear. i come to drive next morning and the clutch is grabbing all low. im curious while im driving and i pull over and see that theres no fluid in there. i do not remember seeing any fluid on the driveway so im curious where it could have went to? anyone have any ideas? its a 93 civic
Was there fluid in there prior to that? Leaving it in gear won't cause fluid to leak. Check the slave cylinder and the lines.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0p_sh0tta »</TD></TR><TR><TD CLASS="quote">Was there fluid in there prior to that? Leaving it in gear won't cause fluid to leak. Check the slave cylinder and the lines.</TD></TR></TABLE>
Check inside to see if the master cylinder is leaking also.
check all the hard lines from the clutch cylinder to the slave cylinder on the tranny. my friends greddy intake pipe rubbed on his metal line and he was losing brake fluid ever day untill we found the problem
I would bet that ur slave cylinder is dead i had one go out on me not long ago. I had to drive home with no freakin clutch
YES OF COURSE THERE WAS FLUID, MY EBRAKE IS NOT THAT GREAT, MAYBE THE PRESSURE CAUSED SOMETHING. I CANT FIND NO LEAKS!!!
check the slave and master cylinders.. chack all the lines and connections.. bleeder valve also... and check the inside of the car for clutch fluin on the drivers side rug..
DeViuS
Feb 17, 2021 11:33 AM
civictype-r
16
Mar 30, 2007 06:37 AM
