i replaced clutch master cycl. car still wont go into gear??
Old 03-23-2007, 10:27 AM
civictype-r's Avatar
Default i replaced clutch master cycl. car still wont go into gear??
clutch pedal goes to the floor and doesnt come back up and car still wont go in gear
Old 03-23-2007, 10:29 AM
bradykiller's Avatar
Default Re: i replaced clutch master cycl. car still wont go into gear?? (civictype-r)
Did you hook the pedal back up the MC?
Did you rebleed the system?
Old 03-23-2007, 10:32 AM
jeffsciv23's Avatar
Default Re: i replaced clutch master cycl. car still wont go into gear?? (bradykiller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bradykiller &raquo;</TD></TR><TR><TD CLASS="quote">Did you hook the pedal back up the MC?
Did you rebleed the system?</TD></TR></TABLE>
lol, for real. first thing you should do is check for fluid in the resivoir, if there is fluid i would follow the lines from the master to the slave and check for leaks.
Old 03-23-2007, 11:08 AM
its bleed,and full cant find any leaks??
Old 03-23-2007, 11:11 AM
Unceasing Measure
Archidictus's Avatar
Maybe you should tell us what originally led you to replace the MC. Did you put a new transmission or clutch on? What happened? Help us help you, noob.
Old 03-23-2007, 11:18 AM
Hyaboosta's Avatar
Default Re: i replaced clutch master cycl. car still wont go into gear?? (Archidictus)
how much did you bleed the system. When I change a slave I have to bleed it even after solid fluid comes out to purge the air from the start of the system. Did you make sure that at no point during bleeding that the resiviour ran out of fluid?
Old 03-23-2007, 11:21 AM
ok last friday had some trouble getting in my driveway cause of the ice,monday i went to move the car and it wouldnt go into gear.the resivoir was empty added fluild still wont go into gear.behind my rug was wet by the clucth master cycl. so i replaced today filled everything up and bleed it now the pedal stays at the floor and wont come up.dont know what else to check.
Old 03-23-2007, 11:24 AM
it did stop then it started again.should i try it some more?
Old 03-23-2007, 12:13 PM
Old 03-23-2007, 12:20 PM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictype-r &raquo;</TD></TR><TR><TD CLASS="quote">it did stop then it started again.should i try it some more?</TD></TR></TABLE>
you should of replaced the slave cylinder as well.
keep bleeding it. it'll take a while, but you will get it.
you do know how to bleed it right, right?
Old 03-23-2007, 12:34 PM
Hyaboosta's Avatar
Default Re: i replaced clutch master cycl. car still wont go into gear?? (philosofy1)
yeah it takes time for the pedeal to come up. you are bleeding it from the slave right?keep pumping the pedal by hand and keep a close eye on the reviour as you do it cause if it goes dry you'll just suck more air into the system.
Old 03-23-2007, 12:41 PM
deadline's Avatar
when you replaced the master cylinder did you replaced the sleeve cylinders too ?
Old 03-23-2007, 12:58 PM
no didnt do the slave cycl. but im getting some pressure in the pedal but it still down low.i didnt set the piece that the pin from the pedal goes in could that be part of the problem
Old 03-23-2007, 03:49 PM
Old 03-23-2007, 03:50 PM
still wont go into gear,pedal still low to floor
Old 03-23-2007, 04:01 PM
byronl's Avatar
u have to change the slave, this happened to me when i did my conversion.
Old 03-30-2007, 06:37 AM
dimwitrj's Avatar
I'm having the same problem. I changed my slave and the one I removed from the car looked bad so i thought i fixed the problem. I got pressure to the pedal after I changed the slave but it wouldn't go into gear. Now I changed the master too and bled the system. It went into gear nicely right after I bled the system then afterwards it would be hard and then later it wouldn't go in at all. I bled again and the same thing. Any help?
pair8hd
16
03-11-2020 06:40 PM
7sins
08-24-2006 11:06 PM
707EF8
07-29-2006 08:09 PM
R.a.w.
05-18-2005 03:41 PM
allmotor.net
05-23-2004 08:53 PM
Quick Reply: i replaced clutch master cycl. car still wont go into gear??
