what is a good tranny for the d16z6
Old May 23, 2004 | 12:10 AM
allmotorEG-SI's Avatar
Default what is a good tranny for the d16z6
just got another 94 si yesterday and i have the 3rd gear crunch and wanted to know if there was a better trannt out there then the one that came with the car?
Old May 23, 2004 | 12:12 AM
AzCivic1.6's Avatar
Default Re: what is a good tranny for the d16z6 (allmotorEG-SI)
the y8 is a little stronger. try some GM synchromesh before getting another tranny though.
Old May 23, 2004 | 01:14 AM
mikehawkBUiLT's Avatar
as stated above the y8 is probably the best sohc tranny you can have. shorter gears than a z6 i presume? other than that, the z6 tranny is pretty damn close to a y8 tranny.
Old May 23, 2004 | 01:19 AM
menkio's Avatar
Default Re: (EJcoupe)
ek ex
Old May 23, 2004 | 06:49 AM
EG8 Dimitri's Avatar
Indeed the Y8. 5th Generation people like to either swap a D16Z6 Ex/Si or D16Y8 EX transmission.
Indeed, invest in some Pennzoil Synchromesh and see if that clears it up after a few hundred miles or so. If not, swap it out with a D16Y8 transmission.
Old May 23, 2004 | 06:50 AM
BlownVR's Avatar
Default Re: (EG8 Dimitri)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG8 Dimitri &raquo;</TD></TR><TR><TD CLASS="quote">Indeed the Y8. 5th Generation people like to either swap a D16Z6 Ex/Si or D16Y8 EX transmission.
Indeed, invest in some Pennzoil Synchromesh and see if that clears it up after a few hundred miles or so. If not, swap it out with a D16Y8 transmission.</TD></TR></TABLE>
Thats a good post, they also like the mini me swap also!
Old May 23, 2004 | 11:07 AM
Aquafina's Avatar
Default Re: (CivicVXHatch)
D16Y8 and D16Z6 gearing is exactly the same. D16Y8 has a steel shifter fork versus aluminum (thanks for correcting me). Transmission fluid is not a fix for a grind, all it does is make it last a while longer before having to replace the synchro.
Modified by Aquafina at 11:58 PM 5/23/2004
Old May 23, 2004 | 11:13 AM
skip.two's Avatar
Default Re: (Aquafina)
yes, the D16Z6 and the D16Y8 transmissions are the same, except for the fact that the Z6 has aluminum shift forks, and the Y8 has steel shift forks. that's the only reason why the y8 is better.
Old May 23, 2004 | 11:16 AM
AzCivic1.6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Aquafina &raquo;</TD></TR><TR><TD CLASS="quote">D16Y8 and D16Z6 gearing is exactly the same. D16Y8 has an aluminum shifter fork versus steel (I think, correct me if I'm wrong). Transmission fluid is not a fix for a grind, all it does is make it last a while longer before having to replace the synchro.</TD></TR></TABLE>
the z6 has aluminum(weaker) shift forks, the y8 has steel. the synchromesh has cured my 3rd gear grind for around 5 months now.
Old May 23, 2004 | 07:57 PM
Aquafina's Avatar
Default Re: (AzCivic1.6)
I'll edit my post.
Does the Y7 have the steel shifter fork as well?
Old May 23, 2004 | 08:04 PM
skip.two's Avatar
are you suggesting him to get a Y7 tranny? don't get a Y7 tranny (even if it has steel shift forks), unless you're that desperate (need tranny now, gas mileage, etc...). if you need a new or different SOHC tranny, i suggest you get the Y8 or Z6.
Old May 23, 2004 | 08:53 PM
Aquafina's Avatar
Default Re: (jL iLLuZiOnz 9)
No I wasn't, osrry if it seemed that way.
I have the stock Y7 in my car and am going to be putting a tranny together and was wondering if the Y7 has steel shift forks as well.
Old May 24, 2004 | 01:10 AM
how close are the gear ratios from a y8/z6 tranny to a gsr tranny (y80?)
Old May 24, 2004 | 05:44 AM
Terrabomb's Avatar
Am I correct in saying the your EX, my SI tranny is the s20?
Old May 24, 2004 | 06:58 PM
thanks guys. I'll pick up some snycromesh fluid asap
Old May 24, 2004 | 09:11 PM
Br1anPham's Avatar
Default Re: (allmotorEG-SI)
either the z6 or the y8 is good like stated above. I think the y8 has a different backup light sensor plug then the z6, but you can just cut and soldier your old plug on. If your looking for the gears on a sohc, i think MistaBone stated that 1st and 2nd gear off a z6/y8 and 3rd/4th off a jdm zc, and you should just get a vx/cx or dx/lx 5th to save gas.
bowdown201
Sep 18, 2007 10:32 AM
ALLMOTOR EK
Jun 20, 2007 06:53 PM
Tom123456
Jul 28, 2006 12:32 AM
tobe1424
11
Dec 6, 2005 09:43 PM
ME SO FST
34
Jan 28, 2005 10:49 AM
