91 accord blower motor replacement
Old May 22, 2004 | 11:15 PM
jshep's Avatar
Default 91 accord blower motor replacement
I've followwed the haynes manual steps for removing the blower motor housing, but there doesn't seem to be enough clearance to remove it. it's loose, but I can't get it out. do I need to remove the dash? Or remove the a/c evaporator? or what? THANKS!
Old May 23, 2004 | 03:47 AM
bill-71SS's Avatar
Default Re: 91 accord blower motor replacement (jshep)
there are a couple of bolts on the side of dash,take them out and pull dash forward enough to get housing out,it is tight,but will come out
Old May 23, 2004 | 09:37 AM
jshep's Avatar
Default Re: 91 accord blower motor replacement (bill-71SS)
Thank you so much for responding!
OK, I did loosen those bolts yesterday and pull the right side of the dash ot a bit. Still no luck. There is a metal bracket just to the right of where the glove-box was. That seems to be causing the most resistance, but I cannot get a wrench on any of the three nuts holding it on. these are four-side rather than hex nuts, for whatever that is worth.
Is it better to try to bring the top edge of the housing away from its bolts first, or the bottom? I've tried both without success.
Thanks again.....
Old May 23, 2004 | 10:23 AM
jpab's Avatar
bill told you correctly. You may hear the dash crack when pulling out on the dash. I have done this on numerous occasions....sounds bad, but you will not see any damage....believe me. Roll the bottom out towards you disconnect the wiring on the right side. Try not to damage the squirrel cages when removing them from the motor. I have on occasion broken them....they can be difficult to remove. gl...JP
Old May 23, 2004 | 11:04 AM
Chiovnidca's Avatar
It helps to peal back the carpet and remove the ECU and TCU.
Old Aug 6, 2004 | 02:27 PM
jshep's Avatar
Default Re: 91 accord blower motor replacement (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">It helps to peal back the carpet and remove the ECU and TCU.</TD></TR></TABLE>
ECU and TCU?
Anyway, I did get it out, thanks for the suggestions! There was a bracket behind those two bolts on the right hand side that had to come out first.
Now, I suspect there might be a problem with the blower motor resistor. The motor work and gets 12v when the switch is fully on. Nothing when on the lower settings. Another funny thing is that it didn't work at all before I took it all apart....
Suggestions?
THanks!
John
Old Aug 6, 2004 | 04:37 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jshep &raquo;</TD></TR><TR><TD CLASS="quote">
Now, I suspect there might be a problem with the blower motor resistor. The motor work and gets 12v when the switch is fully on. Nothing when on the lower settings. </TD></TR></TABLE>
Could be a bad blower resister.
Old Aug 8, 2004 | 07:46 AM
jshep's Avatar
Could be a bad blower resister.</TD></TR></TABLE>
Isn't that what I last said?
I'm still curious about ECU and TCU........
Old Aug 8, 2004 | 09:09 AM
Chiovnidca's Avatar
I was agreeing with you, could be a bad switch too though.
I'm still curious about ECU and TCU........</TD></TR></TABLE>
What about them?
Old Aug 8, 2004 | 09:17 AM
jshep's Avatar
Gotcha.
What about them?</TD></TR></TABLE>
You said I should peel back the carpet and remove ECU and TCU. I don't know what those are.
I also misunderstood your sig before. I thought someone made that comment about spewing coffee on their keyboard about what you said about ECU and TCU. I couldn't see what was so funny.
All in all, it doesn't matter. I've got everything working and back together. Don't really know what was the matter, maybe a loose connection. All I did was take everything apart and put it back together and now it works. SCARY.
Thanks to the people who gave me tips at the beginning of this thread! You really helped me get through, and I was really frustrated getting that housing out at one point.......
Old Aug 8, 2004 | 09:23 AM
Chiovnidca's Avatar
Engine and transmission control units. Taking them out makes getting the blower box in and out alot easier.
Old Sep 29, 2014 | 04:00 PM
ksmAccord's Avatar
ECU and TCU?
Brought this thread back from the dead to say THANKS!!! I spent a LONG TIME trying to get the ECU and TCU connectors disconnected yesterday to no avail on one of them. Removing that bracket, held on by two bolts on the side of the dash, was key (visible after pulling the dash side forward a bit). After removing that bracket, there was plenty of clearance to drop the blower and to reinstall it even after I had re-secured the ECU/TCU bracket. And I didn't risk yanking out any leads from those ECU/TCU connectors. Thanks again!
redtrumpet67
Nov 9, 2017 02:55 AM
revemoto
Jul 16, 2009 09:55 PM
Hondaman56
Sep 20, 2008 02:57 PM
ej6hatchie
Paint and Body
May 14, 2008 09:48 AM
blazeaglory
Feb 12, 2007 03:14 PM
