How do you cc a head?
Old Nov 8, 2001 | 09:16 AM
HX_Guy's Avatar
Default How do you cc a head?
I know the CRV/LS head has a combustion chamber volume of 45cc stock,
but if I de-shroud (open up the chamber bore to match the cylinder bore) it will change the cc's.
How do I go about measuring the new cc's?
Old Nov 8, 2001 | 11:06 AM
earl's Avatar
Default Re: How do you cc a head? (HX_Guy)
YES..Set head on the bench perfectly level. (Valves must be installed.) Cover combustion chamber completely with
piece of clear plastic/lexan with small hole in it. Fill combustion chamber with fluid measured from graduated cylinder. See how much fluid the chamber will hold by reading how much came out of graduated cylinder. All chambers should be made equal volume if you are really blueprinting the engine.
Earl
Old Nov 8, 2001 | 11:10 AM
Spade's Avatar
Default Re: How do you cc a head? (earl)
Cool
Old Nov 8, 2001 | 11:22 AM
HX_Guy's Avatar
Thanks, sounds "easy" enough.
How about finding the displacment of a piston dome..any idea on how to go about find this out?
Old Nov 8, 2001 | 11:29 AM
Spade's Avatar
my guess would be to take the graduated cylinder and put the top of the piston in it? Then see what it displaces?
Old Nov 8, 2001 | 11:32 AM
HX_Guy's Avatar
Default Re: How do you cc a head? (Spade)
How far down though? To where the quench pads touch (are flush) with the liquid?
Old Nov 8, 2001 | 02:31 PM
Spade's Avatar
that is what I would think.....are you going with a dome or a dish?
andrew714
Engine Machining & Assembly
Feb 17, 2016 07:10 PM
deascendent
Apr 3, 2004 08:39 AM
jdstoledo
Apr 6, 2002 03:54 PM
jdstoledo
Apr 6, 2002 12:37 PM
