driver side window only comes down 1/3 of the way
check to see if the regulator (track the window goes up and down on) is blocked or something
powered or not?
powered or not?
Guest
Posts: n/a
its power
i dont think its the motor because it goes down some, then it starts clicking, like maybe something is blocking it from going down further. is there a way to check the path the window goes down to see if something is blocking it. or a fuse
Have you taken your door panels off before? If so, maybe when you put it back on your tightened it down to much. Happend to my friends. That or try taking it off and putting it back on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by southphillyman »</TD></TR><TR><TD CLASS="quote">in my 91 accord ex.
what causes that and is there an easy fix. cause i heard someone say it'll cost $300 if i take it to a shop</TD></TR></TABLE>
i thought some windows only open 1/3 way.. ooh wait thats passenger windows...
its not too hard. then again ive only done it with a special prying tool
its not hard to take it off, we had this problem on my friends civic. turns out the window was off track so we had to re-align it. good luck
