Power window issues
Power window issues
Hey i got a, hopefully, small problem. I have a 03 accord ex v6 2dr coupe and a few days back the passenger window wouldn't go down but then a few minutes later it worked, now the window doesn't go down at all, any ideas?
Re: Power window issues (krosrunner)
Check the master window switch. I've seen my fair share break. If you take it out and look on the underside you may if yours is broken actually see it physically. Usually see it on the driver's button cause of all the use. It only takes a few minutes to check.
If thats not the problem. Pull the door panel and check to see if your getting battery voltage to the motor and check for a good ground. ?Make sure you leave both switches plugged in when checking obviously. Post back when you check.
My Name is Nobody
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krosrunner »</TD></TR><TR><TD CLASS="quote">Hey i got a, hopefully, small problem. I have a 03 accord ex v6 2dr coupe and a few days back the passenger window wouldn't go down but then a few minutes later it worked, now the window doesn't go down at all, any ideas?</TD></TR></TABLE>
You may have hit the master child safe switch
brandon123789
07-23-2019 08:03 PM
WHiTETYPEs
02-09-2005 08:57 PM
southphillyman
05-23-2004 04:56 PM
