Knife edge crank?
Old Nov 8, 2001 | 08:04 AM
Rhetoric's Avatar
Default Knife edge crank?
What does 'knife edging' the crank give performance wise? Is it just to shave weight off of the crank? My motor is apart so I'm wondering if knife edging would be something beneficial? Would it cause problems down the line? Any help appreciated.
Old Nov 8, 2001 | 08:07 AM
hybrid_eg's Avatar
Default Re: Knife edge crank? (G S R)
i heard its a good idea to let the motor rev a little faster.. dont take off 7-8lbs like some peeps do.. 4-5lbs would be more then enough.. i heard this from a reliable source.
Old Nov 8, 2001 | 08:10 AM
Big Phat R's Avatar
It reduces rotating mass and thus inertia. It also cuts down on oil atomization due to high rpms.
If you reduce the weight too much - your engine may have the propensity to stall more often - especially if you use a heavy clutch and lightened flywheel. Your revs will rise and fall much more quickly too.
Anything that reduces the mass of the rotating assembly will allow the engine to rev higher will less strain on the engine components.
Old Nov 8, 2001 | 08:11 AM
Mike M's Avatar
Founding Member
Default Re: Knife edge crank? (Big Phat R)
Dont bother, just balance your crank rods and pistons, and get a lightweight flywheel.
Old Nov 8, 2001 | 10:33 AM
Mike K's Avatar
Default Re: Knife edge crank? (TypeRmsm)
I agree.. just be sure to balance everything properly and you'll be money.
Old Nov 8, 2001 | 12:58 PM
b00st-0wnz's Avatar
From: Drinking Beer in sunny FL and jamming to Skid Row, USA
Default Re: Knife edge crank? (73rd 2000 ITR)
my crank is getting index ground, oil holes enlarged and chamfered, weights detailed and de-flashed, straightened and nitride hardened and micropolished.
Oh yeah... that's for my $900 beater. oops.
Old Nov 8, 2001 | 02:51 PM
topspeed86's Avatar
Default Re: Knife edge crank? (Dave-ROR)
OEM cranks are tuftrided and nitrided from the factory.
Gotta love Honda.
Pablomg
May 13, 2019 03:16 AM
orca
Feb 12, 2005 04:05 PM
B16A1-EF9
Nov 20, 2004 08:01 AM
choiboiracing
Apr 8, 2004 09:44 AM
omega11855
Nov 23, 2003 01:59 AM
