knife edged crank vs. f/i
Old Feb 11, 2005 | 01:31 AM
orca's Avatar
Default knife edged crank vs. f/i
I maybe want to use a knife edged crankshaft in a f/i B18C6. What's your opinion on that? I want to boost not more than 1.2 Bar (17 psi) 'cause i also use the car on track.
I know, Honda engines have a windage tray, but for me it's important to have a lighter crankshaft: less mass = better response. Is that save? The crank is well balanced, so vibrations are not a problem (i used the same crank in my 2 Liter n/a engine). I'm afraid, that a knife edged is not that solid as a stock crank.
Anyone have experience with that combination?
Old Feb 11, 2005 | 04:07 AM
rioninja's Avatar
Default Re: knife edged crank vs. f/i (orca)
Try a lighter flywheel.
Old Feb 11, 2005 | 04:28 AM
Boostage's Avatar
Default Re: knife edged crank vs. f/i (rioninja)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rioninja &raquo;</TD></TR><TR><TD CLASS="quote">Try a lighter flywheel. </TD></TR></TABLE>
I agree dont mess with such a good factory peice.
Old Feb 12, 2005 | 03:23 AM
orca's Avatar
Default Re: knife edged crank vs. f/i (Boostage)
Well i already have a lighter flywheel. And also a knife edged crank. The question is, is a the crank with less mass strong enough for a boosted engine?
Old Feb 12, 2005 | 03:45 AM
N20civicB18's Avatar
could try it and let us know? if you wanted to go even lighter i would try a ctr n1 pully first
I dont know what kind of racing you do but if you do drag then lighter isnt always better...
Old Feb 12, 2005 | 04:05 PM
orca's Avatar
Default Re: knife edged crank vs. f/i (N20civicB18)
I use my car for road racing, so good response is important.
So nobody here tried that?
Pablomg
May 13, 2019 03:16 AM
hplssone
Jan 21, 2008 10:24 PM
B16A1-EF9
Nov 20, 2004 08:01 AM
BoostedH23Accord
Oct 2, 2004 01:41 AM
