Question about D16A8
Old May 22, 2004 | 10:34 AM
dra600n's Avatar
Default Question about D16A8
I have a D16A8 (JDM ZC DOHC 1.6)
Can I put a D16Z6 or a D16Y8 head on my ZC without any problems? Will it bolt on without any fabrication, and would it work? If so, how well would it work in comparison to the stock ZC head? I know I would need to either get a reprogrammed ECU or a VTEC controller to actually get VTEC to work..
Thanks for the help and info
Old May 22, 2004 | 10:38 AM
JCracer723's Avatar
Default Re: Question about D16A8 (dra600n)
no no no DOHC and SOHC = not the same ****
Old May 22, 2004 | 10:42 AM
dra600n's Avatar
Default Re: Question about D16A8 (JCracer723)
http://crx.honda-perf.org/arti....html
Thats where I got the information at. Is there any way to turn it into a VTEC or no? If so , what would I need?
Old May 22, 2004 | 10:49 AM
crxgator's Avatar
are you sure you have a d16a8? cause you would be the first i have heard of one in the states...you know that engine was only in europe...maybe you read it wrong and have a d16a6? do you have pics?
Old May 22, 2004 | 11:00 AM
dra600n's Avatar
Default Re: Question about D16A8 (crxgator)
Yep, I got some pics:
http://lord.dragoons-lair.com:8080/IMG0123.jpg
http://lord.dragoons-lair.com:8080/IMG0124.jpg
Also, if you have AIM, IM me: Aw Killa 04
Old May 23, 2004 | 05:20 AM
dra600n's Avatar
bump
Old May 25, 2004 | 03:00 PM
hahahahhah's Avatar
aren't all JDM ZC engines either D16A8/D16A9???
Old May 25, 2004 | 04:34 PM
ZCdohcHB's Avatar
does it say D16A8 or ZC?
i'm positive that u have a ZC due to ur valve cover. D16A8 does not have that valve cover only ZC dohc motors do.
don't get me wrong, D16A8 and ZC dohc motors are both the same. spec wise but have different valve cover
Old May 25, 2004 | 04:45 PM
crxgator's Avatar
Default Re: Question about D16A8 (ZCdohcHB)
im pretty sure that they have the same exact vavle cover d16a8/9 and the zc...from what it looks like it says ZC on the timing belt cover but i need a pic of the actual engine code to be sure since you cant assume anything with just a cover since they get changed all so easily...
Old May 25, 2004 | 05:10 PM
hahahahhah's Avatar
so are the D16A8/A9 JDM and the ZC USDM or what? I don't get it
Old May 25, 2004 | 06:15 PM
crxgator's Avatar
Default Re: Question about D16A8 (edmCRX)
no D16A8/9 are from europe, ZC is from japan d16a1 is from usdm integras...north america never got the zc...
Old May 25, 2004 | 06:38 PM
ham's Avatar
ham
nothing on the dohc ZC is really compatible with any other H motors
Old May 25, 2004 | 07:36 PM
ZCdohcHB's Avatar
who is talking about H motors?
Old May 25, 2004 | 07:51 PM
crxgator's Avatar
Default Re: (ZCdohcHB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZCdohcHB &raquo;</TD></TR><TR><TD CLASS="quote">who is talking about H motors?</TD></TR></TABLE>
h mean honda motors not h-series...
Old Jun 6, 2004 | 09:05 PM
- advanced -'s Avatar
I have a D16A8, im from australia.
I need to clarify this, as ive been asking myself this all the time.
Is the ZC identical to my motor?
Same specs?
From what ive heard, the ZC has a slightly higher fuel map
Can anyone clarify this?
jclutch21
10
Aug 31, 2011 10:35 AM
SIR EF9
Feb 13, 2009 03:54 PM
hatch96y7
Sep 10, 2006 06:50 PM
E dwinbon G
Jan 20, 2003 07:52 AM
OEMJDM
Jan 4, 2003 12:01 PM
