Jumping idle while stopped.
Old May 22, 2004 | 10:21 AM
Erod's Avatar
Default Jumping idle while stopped.
I THINK this only happens when I'm stopped and its hot (like today) and the fan is kicked on. The cars idle jumps to about 1500 then back to 1000 repeatedly. Any ideas? (JDM d15b)
Thanks
Old May 22, 2004 | 10:36 AM
=GAME='s Avatar
Default Re: Jumping idle while stopped. (Erod)
vaccuum leak, IACV, loose FITV.
Old May 22, 2004 | 10:45 AM
Erod's Avatar
Default Re: Jumping idle while stopped. (=GAMEOVA=)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by =GAMEOVA= &raquo;</TD></TR><TR><TD CLASS="quote">vaccuum leak, IACV, loose FITV.</TD></TR></TABLE>
English please? Where should I look for these problems/what are they? Thanks
Old May 22, 2004 | 10:46 AM
jameskersten1's Avatar
check your vac lines. the iacv is the little black film container looking thing on your intake.rmeove it and clean it out.
Old May 22, 2004 | 12:15 PM
Erod's Avatar
Default Re: Jumping idle while stopped. (jameskersten1)
Got a pict? Not sure where its at.....I looked.....
Old May 23, 2004 | 07:21 AM
Erod's Avatar
*bump*
Old May 23, 2004 | 07:45 AM
H22A EG6's Avatar
OMFG do a search this damn thing gets covered at least once a day
number 9/11
edit: i got it mixed up number 14
Modified by H22A EG6 at 4:06 PM 5/23/2004
Old May 23, 2004 | 09:57 AM
Br1anPham's Avatar
Default Re: Jumping idle while stopped. (H22A EG6)
i dont think number 9/11 is the idle air control valve buddy.
IACV:
take it out, i think its 2 10mm bolts, and two hoses clamped on the bottom
Then when its out, just spray it with carb cleaner and clean it. its recommended that you change the gasket too.
Old May 23, 2004 | 04:09 PM
Erod's Avatar
Default Re: Jumping idle while stopped. (Br1anPham)
exxxxcceellnnt &lt;/Mr. Burns&gt;
Thanks a lot.
Old May 23, 2004 | 04:24 PM
trooper0641's Avatar
i had the same exact problem as you did...and the problem was...that your throttle cable was too tight. (seriously) loosen it up and it'll idle back to 800 rpm
Toe_Knee
Feb 11, 2008 08:51 AM
Pure Sol
16
Dec 31, 2007 12:06 PM
94c1v1cex
Jul 20, 2007 11:15 AM
HondaLude93
Feb 2, 2007 08:36 PM
eg6nes
Feb 21, 2005 03:57 PM
