drag race project car
Old May 21, 2004 | 06:57 PM
engxproject's Avatar
Default drag race project car
I want to do up a little project car for 1/4 mile drag racing. I have a lot of v8 history, but not much honda knowledge.
we have a stuska engine dynomometer, some serious data aquisition, complete automotive machine shop, with computerized boring, sleeving, sunnen ck10, sunnen vgs-20, hines balancer, access to a chassis fabricating shop.....
i am trying to research what the best combo would be.
i am thinking a mid 90's civic hatch, with maybe an integra motor, eagle stroker kit, 7.5 compression, darton sleeves, 30 lbs boost, nitrogen intercooler, a little squirt of nitrous, so my question is, what kind of transmision mods can be done, what is available to hook these little rockets up, who has the best (most versatile)
fuel management setup, i would like to control boost pressure with the computer
i'm trying to learn.... thanks lots!!
Old May 21, 2004 | 07:01 PM
dmotoguy's Avatar
Default Re: drag race project car (engxproject)
what is your goal time-wise with this car?
SEFIxCivic's Avatar
for your efi you want a motec. it can do just about anything u want. boost control, eight 160 lbs injectors, two step, individual cylinder control, on and on
Old May 21, 2004 | 07:07 PM
dmotoguy's Avatar
Default Re: drag race project car (SEFIxCivic)
i dont know if you need to stroke it or not.. and that compression could be a little low, and just use a regular air/water intercooler
Old May 21, 2004 | 07:13 PM
Trooper's Avatar
Default Re: drag race project car (dmotoguy)
If ya wana get crazy you can run upwards of 11-1 on methanol for a turbo car. As far as trannies, be prepared to spend some$$$ if your gona make power. good luck
Old May 21, 2004 | 07:14 PM
somewhere in the low tens would be nice
Old May 21, 2004 | 07:16 PM
well, my thinking was that if the stock crank and rods would be marginal, and i had to replace with aftermarket, might as well squeeze some more cubes out of it.
what do you suggest? will the stock stuff live?
Old May 21, 2004 | 07:38 PM
dmotoguy's Avatar
crank will
Old May 21, 2004 | 07:43 PM
94gsr4dr's Avatar
Crank will be fine, but i would ditch the other stock internals.
swapped hatch
Sep 1, 2012 04:48 PM
Innes
Aug 2, 2011 07:37 PM
Silva Bullit DC4
Jun 29, 2011 09:33 PM
engxproject
May 21, 2004 06:47 PM
Etylorcen
Nov 22, 2001 02:05 PM
