Oil pan bolts??
Old May 21, 2004 | 04:56 PM
NSTY Z33's Avatar
Default Oil pan bolts??
I got my block and i'm looking to get some new oil pan bolts. Some missing, some broken. Where can i get a new set for a good price. My block also cam with some broken ones and i have no idea how i'm going to remove them from the block. Any help would be great!!!
Old May 21, 2004 | 07:22 PM
AL ASPIRATED's Avatar
u need an extractor kit, you can buy one at sears.
u need to drill a little hole then use the right extractor, tap it in there and turn it counterclockwise with a wrench.
as for finding the bolts, go to your local junkyard
Old May 21, 2004 | 07:46 PM
NSTY Z33's Avatar
Default Re: (AL ASPIRATED)
Junkyard?? Where can i get some NEW ones.
Thanks for the help though I gotta drill another hole into my block though????? I don't think that will be happening
Anybody else?
Old May 21, 2004 | 08:30 PM
im_poor's Avatar
Default Re: (JDMCRXDelSol)
i have some bolts and nuts for the pan. 10mm
Old May 21, 2004 | 10:36 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMCRXDelSol &raquo;</TD></TR><TR><TD CLASS="quote">Junkyard?? Where can i get some NEW ones.
Anybody else?</TD></TR></TABLE>
well i can jus think of honda to get them new, but no you do not drill in the block, you drill a little hole in the bolt that is stuck in the block, then you take the extractor to take out the broken stud or bolt. this way you can put a new bolt in the same whole.
Old May 21, 2004 | 11:19 PM
N2O's Avatar
N2O
Any 10mm bolt will work fine. They do not have to be Honda bolts. As for removing the bolts. First try to use a thin piece of metal rod (I.E. hanger) and try to put a dab of crazy glue on the end and glue it to the broken bolt. At times when a bolt brakes the piece that is left in the hole is real loose. If that does not work use the EZ-Out that they spoke about. Do not worry about drilling a hole in the screw. You do not have to drill very deep at all just a small dimple works well at times.
sk8shorty012
Nov 2, 2006 02:34 PM
RTW DC2R
Jun 25, 2006 04:26 PM
menkio
Oct 4, 2004 12:30 PM
Mag00n
May 8, 2004 08:43 AM
Mag00n
May 1, 2004 06:09 PM
