This Happen today :(
This pic is from the rear bracket of my tranny...
The 2 19mm bolts going into the tranny are stripped, I was going to Helicoil it this weekend, but today this happen.
What should I do? Could I still Helicoil the tranny?
i dont think jb weld will be good enough to repair that, that mount is the main one that distributes the torque, if you jb weld it it will just break, i dont think thats ever going to be good, but i would go to a local machine shop iand see if some one can weld it and then re-tap it, but thats just me.
JB weld will NOT hold that. I had a similar situation like that happen to the hole where my slave cylinder bolts in, so I JBwelded in a stud. I know for a fact that JB weld will NOT hold your tranny to your rear mount bracket. I would take the tranny to a machine shop and have them properly weld in new material and then re-tap as stated above.
had the same thing happen to one of my cars, and i JBwelded it. ive been beating the **** out of it for about 7 months now. no problems. maybe im just lucky.....................?????
you definatly need 2 bolts in the rear...i had 1 break, then kept the other one in...and that broke then...get that fixed asap, or you can just replace that side of the case with any b-series i believe.
fasterthenmost
Feb 4, 2006 06:06 AM
Nerologic
11
Jun 21, 2004 12:39 PM
