ignition switch
i am trying to install a a/f gauge .
i have a 92 vx b16a2
but i am trying to find out where is my ignition switch
can someone take a pic of that wire ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GReddy SI »</TD></TR><TR><TD CLASS="quote">ok where is my ignition switch i have to tap for my a/f gauge
its a mess here
you're looking at the wrong place, the ignition switch is on the steering wheel. just remove the upper and lower plastic cover that covers the steering wheel. look directly under the steering wheel and trace the wires from the ignition lock to the switch. the switch is held up by 2 bolts. pretty simple if you have this: http://www.helminc.com
would've saved you alot of time and effort if you would've gotten this in the first place.
btw john666 has the easier route to tap into the igniton wire.
its a mess here
</TD></TR></TABLE>you're looking at the wrong place, the ignition switch is on the steering wheel. just remove the upper and lower plastic cover that covers the steering wheel. look directly under the steering wheel and trace the wires from the ignition lock to the switch. the switch is held up by 2 bolts. pretty simple if you have this: http://www.helminc.com
would've saved you alot of time and effort if you would've gotten this in the first place.btw john666 has the easier route to tap into the igniton wire.
EH3 JR
Apr 27, 2009 04:43 PM
