d16z6 bottom with y8 head what arp head bolts to use?
Old May 21, 2004 | 10:30 AM
egturbo's Avatar
Default d16z6 bottom with y8 head what arp head bolts to use?
hello guyz just wondering what head bolts i can use for this setup tahnks
i have y8 arp head studs can i use those?
can i use the thermastat, oil pump, water pump, timing belt and other parts off of my y8 on the z6?
Modified by egturbo at 3:29 PM 5/22/2004
Old May 21, 2004 | 11:29 AM
egturbo's Avatar
Default Re: d16z6 bottom with y8 head what arp head bolts to use? (egturbo)
Old May 21, 2004 | 11:33 AM
M.A.R.C.'s Avatar
use the ones for whatever block it is. that's what i have. the head isn't on yet but i researched and the only thing is u'll need some washers for like 2 of the headstuds cause they're longer than the y8 ones or osme hsit
Old May 22, 2004 | 12:28 PM
egturbo's Avatar
sxf
Old May 22, 2004 | 01:13 PM
Cruiser G's Avatar
This might help https://honda-tech.com/zerothread?id=758589
Old May 22, 2004 | 02:22 PM
egturbo's Avatar
Default Re: d16z6 bottom with y8 head what arp head bolts to use? (Cruiser G)
nice thanks. so ur using y8 studs? can anyone answer the other questions
Old May 22, 2004 | 03:39 PM
Cruiser G's Avatar
I'm either going to use a z6 or y8 head on my z6 block, but either way I'm gonna use z6 studs.
Old May 22, 2004 | 05:20 PM
egturbo's Avatar
oh then should i be using z6 studs also? cuz i have y8 thats my question? tia
Old May 22, 2004 | 06:11 PM
Cruiser G's Avatar
yea, Im pretty sure you use z6. Use the same as the block your using.
Old May 22, 2004 | 07:54 PM
egturbo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cruiser G &raquo;</TD></TR><TR><TD CLASS="quote">yea, Im pretty sure you use z6. Use the same as the block your using.</TD></TR></TABLE>
k thanks. i guess i have to buy a new set. do u know anyone that sells them cheap i need some asap.
red civic standard
Mar 26, 2007 07:56 AM
THEDirtyDseriesWOOT
Nov 3, 2006 03:40 PM
turbo sol
Mar 2, 2006 11:57 AM
d15b7racer
Oct 16, 2004 07:27 AM
Cruiser G
Feb 6, 2004 11:26 AM
