Oil Pump Difference
Old May 21, 2004 | 06:44 AM
93H22ACX's Avatar
Default Oil Pump Difference
What is the difference in oil pumps from 92-96 H22's and 97-2001 H22's?
Price for the 92-96 H22's are more expensive too?
Any ideas?
Old May 21, 2004 | 12:07 PM
iakona's Avatar
OBD I vs. OBD II
sensors in the OBD II pump that are in the distributor for the OBD I pump.
distributors are different too.
Old May 24, 2004 | 02:34 AM
93H22ACX's Avatar
Default Re: (iakona)
so if i use an OBDI distributor...i can still use the odb-II pump right?
Old May 24, 2004 | 04:34 AM
iakona's Avatar
nope. unless you can find a way to plug the holes in the OBD II pump. and ensure that the sensors you need are going to come from the distributor. and even then, i've found that the signal sent by each set of sensors is just slightly different. still within the correct paramenters, just not quite so spot on, so i'm not sure how it will work for you.
Old May 24, 2004 | 04:50 AM
93H22ACX's Avatar
Well...this is going into a 93 OBD-I civic hatch....
It still wouldnt work?
Old May 24, 2004 | 09:48 AM
Speedra500's Avatar
Default Re: (95PRELUDEVTEC206)
yes it will work, I have a similar setup an a '94 hatch, disconnect the OBDII sensors and buy a OBDI distributor and connect the wires that normally went to the pump side and connect them to their correct sensor in the distributor
Old May 24, 2004 | 09:58 AM
93H22ACX's Avatar
Default Re: (Speedra500)
Damn you have to wire up the oil pump too? any wiring diagrams? damn didnt know i had to do that
Old May 24, 2004 | 11:17 AM
satan_srv's Avatar
you just leave the obdii pump and sensor on there...ignore it.
and it was 92-95 that had th obdi oil pump and 96-01 that had the obdii one.
ranger#1
Sep 2, 2012 11:45 PM
Revi
Sep 25, 2006 07:45 AM
coconutsoldier
Jun 18, 2005 05:37 PM
G0dzArmy
Dec 31, 2004 03:18 PM
chirp2hrd
Aug 30, 2002 12:10 AM
