**b16 question**
hey guys if i run my b16 without the b16 exhaust manifold and with the b18 one(doesnt have second o2) will it run fine besides the code? i am thinking of racing it on saterday and need to know if it'll run fine...thx for the help
1st geb B16's are non obd and need a proper signal from both o2 sensors. If throwing a code, youy computer will most likely not go into vtec.
Youy best bet is to weld in another bung into the aftermarket header.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deetz »</TD></TR><TR><TD CLASS="quote">1st geb B16's are non obd and need a proper signal from both o2 sensors. If throwing a code, youy computer will most likely not go into vtec.
Most likely you will still be able to engage VTEC throwing a code, some codes won't allow VTEC to engane though.
I am running the obd 0 pr3 ECU with only 1 o2 hooked up and I am not throwing any codes at all and seems to be running fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roadawg »</TD></TR><TR><TD CLASS="quote">
I am running the obd 0 pr3 ECU with only 1 o2 hooked up and I am not throwing any codes at all and seems to be running fine.</TD></TR></TABLE>
When my car was OBD0 I only ran 1 02 and it never threw a code
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridHatch88 »</TD></TR><TR><TD CLASS="quote">
I am not either but I thought it should be. oh well, like i said it seems to run fine.
</TD></TR></TABLE>I am not either but I thought it should be. oh well, like i said it seems to run fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4by4inaCCord »</TD></TR><TR><TD CLASS="quote">If you want, you can wire the two O2's together.</TD></TR></TABLE>
That's probably the fastest way to take care of it but probably not the best. If you can't get another spot for 2nd O2 welded on then go this route.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 15 degree V »</TD></TR><TR><TD CLASS="quote">
I told you before the car isn't making the power it should because my cams aren't tuned. The o2 seems like it has nothing to do with it. VAFC is on the way.
</TD></TR></TABLE>I told you before the car isn't making the power it should because my cams aren't tuned. The o2 seems like it has nothing to do with it. VAFC is on the way.
SweetDA9_TR
Apr 13, 2009 11:43 AM
CTR-GSR
Mar 13, 2007 03:18 PM
MysteryWagon
Mar 10, 2005 08:07 PM
EFin' Kyle
14
Nov 11, 2004 08:37 AM
