CRX Type R lost to ITR?!
Alright heres the specs of the car
CRX type R:
JDM motor
obd0 Injectors
255 intank fuel pump
Y1 LSD tranny
DC 4-1 headers
Greddy Exhaust
Intake
01 PY ITR:
Intake
Stock exhaust
I lost to my friend with a USDM Type R on the highway. I would think that my car would pull harder cause of its weight but no! We both started off in 2nd going 40mph. His Vtec kicks in first but my car starts to boggle then vtec kicks in at 5.5 -6 RPM and his Vtec is alot louder then mines. He vtec pulls his about a quarter car lenght ahead of me after 3rd gear is over. Does anyone know whats wrong with my car?
CRX type R:
JDM motor
obd0 Injectors
Y1 LSD tranny
DC 4-1 headers
Greddy Exhaust
Intake
01 PY ITR:
Intake
Stock exhaust
1) What ecu are you using in the crx?
2) What is your timing set at?
3) How is your motors compresion/ leak down test check out?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asubennett »</TD></TR><TR><TD CLASS="quote">1) What ecu are you using in the crx?
3) How is your motors compresion/ leak down test check out?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bictorious »</TD></TR><TR><TD CLASS="quote">Alright heres the specs of the car
CRX type R:
JDM motor
obd0 Injectors
Y1 LSD tranny
DC 4-1 headers
Greddy Exhaust
Intake
01 <FONT SIZE="5"><U>PY</U></FONT> ITR:
Intake
Stock exhaust
There's your answer right there. Everyone knows the yellow ITR's are making more power than the other colors
It's not always cut and dry, with the light car winning. There's a huge number of factors, from motor condition, gearing, driver ability/error, etc. As was stated above, make sure your motor is running up to par.
CRX type R:
JDM motor
obd0 Injectors
Y1 LSD tranny
DC 4-1 headers
Greddy Exhaust
Intake
Intake
Stock exhaust
. It's not always cut and dry, with the light car winning. There's a huge number of factors, from motor condition, gearing, driver ability/error, etc. As was stated above, make sure your motor is running up to par.
prolly you using a pr3 ecu which needs a 2nd o2 input or will run like crap ... any CELs ? send your ecu to me to get reprogramed and then race your friend again and come back and post
http://www.gbrtuning.com to see a typical ecu upgrade dyno
I hear this alot from CRX owners with VTEC swaps.
greg
greg
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CHEETAH »</TD></TR><TR><TD CLASS="quote">prolly you using a pr3 ecu which needs a 2nd o2 input or will run like crap ... any CELs ? send your ecu to me to get reprogramed and then race your friend again and come back and post
greg</TD></TR></TABLE>
Also, vtec eng... too soon? too late?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">
Im not sure but its an ECU programed by Ericks Racing from cali. I heard he makes 9 second all motor hondas?
Your tranny could have a little to do with it. Check this site out. The ratios on the ITR are a little tighter.
http://www.bseries.net/html/specs/btrannyspecs.php
double check your oil pressure too and what obd0 injectors are u runnin exactly? but like the other guy said check your wiring too i always here about people haveing vtec engagement when droppin in vtec motors into there ef's... well hope u get that runnin back to normal ..
