Bent Valves, Low compression?
Old May 20, 2004 | 11:08 PM
RGoose18's Avatar
Default Bent Valves, Low compression?
I misshifted bad earlier in the day. If I do indeed have bent valves, will my compression test read low, or is there a possibility of it reading normal. Thanks
Old May 20, 2004 | 11:49 PM
mmuller's Avatar
Mad Scientist
Default Re: Bent Valves, Low compression? (RGoose18)
yeah, it can not show if it leaks slowly, on the compression tester you have a check valve so air cant come back into the cyl.; so if pressure builds up and then it leaks it wont show.
If the idle is fine, check valve clearances;; if for example 2 are off then you know
Old May 21, 2004 | 07:30 AM
Ekasey's Avatar
Default Re: Bent Valves, Low compression? (mmuller)
do a leak down test and then listen for where it is leaking from.
Old May 21, 2004 | 10:13 AM
tvrsir's Avatar
you can test if you have bent valves with compression test. if somehow there is low compression the you have bent valve, hg, or rings as the culprit. with bent vavlves comprsion will hit a certain point and remain there evn if you turn the engine over a million times. leakdown will tell you exactly where the leak is. but comprssion will help out too.
JBirch_97Prelude
Mar 9, 2021 03:01 PM
acman1
May 21, 2007 12:06 PM
SwiftTypeR
May 10, 2005 05:22 PM
allmotorls95
Apr 24, 2003 04:37 PM
LostGsr
Jun 15, 2001 12:29 PM
