Wont start Roll it IT STARTS?????? HELPHELP***
Old May 20, 2004 | 05:45 PM
918-Hatch's Avatar
Colorado <3
Default Wont start Roll it IT STARTS?????? HELPHELP***
Okay. I have had this prob for about 3 weeks now. Now it died it front of my house. the check engine light is on but will not throw a code, I rolled the car forwerd and the check engine light went off and I was able to start it. (when it is started it runs like ****..when i try to drive it the check engine light comes on and off and the tach jumps up and down like mad. so I turn it off roll it up alittle bit till the check engine light comes on and it will not start, So i got out and checked to see if it had spark when the check engine light is on. (it had no spark) i roll the car about 6 inchs till the check engine light pops off and it starts and has spark.????????????????????Can anyone help? Thanks I did a search for about 10 min I was just to tired to look anymore. I will check back in a hour or so. Thanks guys.
Old May 20, 2004 | 05:51 PM
BlownVR's Avatar
Default Re: Wont start Roll it IT STARTS?????? HELPHELP*** (918-Hatch)
Damn that sounds crazy, i know my friend with a GSR hatch his starter was just bad so we had to roll it and pop start it, but thats definatly not the case for you, you might want to ask a technician, because your problem might not be able to be solved here on h-t.... but im sorry i could give you and help, i guees just check the main things you think might be wrong with it, wiring,starter?? im not sure though. good luck and hope it's nothing too serious!
Old May 20, 2004 | 06:03 PM
918-Hatch's Avatar
Colorado <3
It cranks just fine.
Old May 20, 2004 | 06:28 PM
LSpimpTEC's Avatar
check your grounds....something like this happened to me and it turned out to be my tranny ground. good luck
Old May 20, 2004 | 06:40 PM
Kidnkorner's Avatar
your ignition control module may be going bad(ignitor) your crank angle sensor may be going bad or getting a false reading due to bearings, your coil my be going bad or all of the above. the only way is to have some use a volt meter on the components inside the distributor
Old May 20, 2004 | 08:15 PM
918-Hatch's Avatar
Colorado <3
Bump.. thanks for the replys.
Old May 20, 2004 | 09:44 PM
918-Hatch's Avatar
Colorado <3
yoyoyoyoyo HELP
sianzsianz
Jul 12, 2006 07:20 AM
2ltrgsr
Jun 7, 2006 04:00 PM
RCautoworks
Dec 20, 2002 02:07 PM
