need help bad please help me
Old May 20, 2004 | 05:26 PM
Icey112's Avatar
Default need help bad please help me
Ive got a built gsr head and bottom end the head has a full skunk2 valve train the valves are the flat top high compression and it has skunk2 stage 1 cams the head has been p/p and str cam gear . I don't know if that will affect any thing and the head has not been milled. The block has eagle rods,weisco mid compression pistons and the bore is 81.5 and with the 3 layer head gasket larry from endyn said my compression is 12-0-1 . But i want to drop the compression too 11-5-1 just to be more safe and 11-5-1 is good for the stage 1's .So i need to know should i clay the motor or what should i do will it be ok or what . please help me thanks
Old May 21, 2004 | 02:15 AM
Icey112's Avatar
Default Re: need help bad please help me (Icey112)
some one has to know some thing
Old May 21, 2004 | 07:34 AM
Ekasey's Avatar
you should clay the motor if your unsure but why would dropping the compression necessarily help? comrpession is the calculation of bore stroke gasket thickness and combustin chamber volume
Old May 21, 2004 | 11:03 AM
Icey112's Avatar
Default Re: need help bad please help me (eLusive ek4)
The cams are stage 1 skunk2's 11-5 is good comrpession for them and 12-1 that high for the cams plus 12-1 makes me scared that im going to blow some thing. a friend was at 11-7-1 bent a valve and spun a rod bearing.
Old May 21, 2004 | 01:30 PM
Ekasey's Avatar
sounds liek your friends motor, was built poorly or incorrectly by soembody with no experience
Dave_Dc2
Oct 16, 2008 10:56 PM
all-mtr-teg
15
Nov 30, 2006 08:43 PM
ice11honda
Apr 28, 2005 03:19 PM
Morhpeous
May 24, 2004 07:19 PM
