progressive vs. linear
Old May 20, 2004 | 04:44 PM
deviant1's Avatar
Default progressive vs. linear
which is stiffer? if you have a 400 progressive spring, whats the equivalent of that in linear? would it be stiffer?
Old May 20, 2004 | 07:03 PM
suspendedHatch's Avatar
Default Re: progressive vs. linear (deviant1)
Progressive springs dont have a rate and there isn't an easy way to calculate their equivalent in linear. One isn't stiffer than the other simply by which type they are, but by the stiffness of the coil itself. It's also possible that a linear rate spring would be stiffer than a progressive under light load, but softer than the progressive spring is when it is under heavy load.
Progressive means that the rate stiffens as you apply more load to the spring. Its a street compromise, so that for most bumps you have a fairly soft rate, but when you corner hard you don't body roll too much. Nearly all aftermarket springs and coilovers are progressive. Racers prefer linear rates because they are more predictable.
You can easily identify them by looking at them. Linear will have even spaces between the coils for the whole spring. Progressive will have small gaps at the top of the spring between the coils, increasingly larger gaps until somewhere near the middle, then the gaps will get smaller again at the bottom of the spring.
dirrrtykorean
Suspension & Brakes
Sep 3, 2008 05:34 AM
EJ8 Kenobi
Suspension & Brakes
12
Jun 1, 2007 06:05 AM
VeilSide_Mas
Suspension & Brakes
Feb 4, 2006 10:08 AM
NA95d16z6
Suspension & Brakes
29
May 5, 2005 09:40 AM
Superhatch
10
Feb 8, 2002 06:59 PM
