h22a swap, immobilizer problems?
Old May 20, 2004 | 01:00 PM
steve_meyer's Avatar
Default h22a swap, immobilizer problems?
Hi there, a friend has a h22a swap into an accord, and has had to use a b16 ecu due to immobilizer problems with his h22 ecu. Any ideas how to fix this, or remove the immobilizer out of his h22a ecu? Thanks in advance
Old May 20, 2004 | 08:19 PM
Default Re: h22a swap, immobilizer problems? (steve_meyer)
bump
Old May 20, 2004 | 09:58 PM
ki11a8ee's Avatar
if the ecu is 97and up then there is no way of getting rid of the immobilizer ull have to find a 96 ecu that is obd2 compatible and comes without the immobilizer.
I ran into the same problem. goodluck
Old May 22, 2004 | 10:27 AM
Default Re: h22a swap, immobilizer problems? (ki11a8ee)
I thought one of the chip installers here mentioned a way of desoldering the chip? Oh well...
Old May 22, 2004 | 12:11 PM
Kal's Avatar
Kal
if it's desoldered, the car simply won't start.
Old May 22, 2004 | 01:24 PM
Default Re: h22a swap, immobilizer problems? (Kal)
So is there any way to safely disable it then?
Old May 22, 2004 | 01:42 PM
supaZZZleepa's Avatar
if he's doing a h22 swap into an accord i dont think he should have any problems becaues he doesnt have an immobilzer in his accord (unless it is a newer accord 98 and up). the immobilizer on the ecu wont affect anything unless an immobilizer in a car is trying to detect it from the ecu.
Old May 22, 2004 | 05:32 PM
Kal's Avatar
Kal
Default Re: h22a swap, immobilizer problems? (supaZZZleepa)
he wants the h22a ecu, and it does have the immobilizer on it.
no, you'll need to use an obd1 prelude ecu like killa said.
93formula
May 9, 2007 06:00 AM
GorData
Feb 5, 2007 05:22 AM
CR-V-tech
Dec 18, 2006 08:19 PM
rz514
May 5, 2006 08:16 AM
Chubs
Sep 12, 2002 12:53 AM
