high idel
Old May 20, 2004 | 11:25 AM
Mike17's Avatar
Default high idel
well after replacing the headgasket in my 88 dx, the engine has a high idel. and i cant find my Haynes manuel, so i figued i would post. anyone know a way i can fix this? and yes i did search but it was no help
Old May 20, 2004 | 12:50 PM
tilt's Avatar
Default Re: high idel (Mike17)
adjust the idle screw
Old May 20, 2004 | 12:57 PM
Tyson's Avatar
check to see if your throttle cable is adjusted too tight. i recently learned it must by adjusted WHILE THE ENGINE IS RUNNING. otherwise, when the engine is off, the dashpot pushes the throttle open a bit, so if you adjust it then, it will be too tight.
but how high? if its like 3000rpm high, then you probably have a vac leak, either a bad vac hose or cracked intake manifold gasket.
Old May 20, 2004 | 01:08 PM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
http://www.binghamtonlife.com/...1.jpg
if you took the throttle cable off....make sure you check your TPS voltages, cause that will really screw with your idle!
FATKID87
Honda CR-V & Element
Mar 26, 2014 07:52 AM
bk7794
Apr 28, 2011 07:55 PM
Hackura
Mar 12, 2009 03:17 PM
CRX30436
Nov 2, 2008 08:39 PM
metal-x
Nov 21, 2002 05:35 AM
