Jumping ECU on OBD2 Prelude to advance/retard timing?
Old May 20, 2004 | 08:01 AM
BB6-213's Avatar
Default Jumping ECU on OBD2 Prelude to advance/retard timing?
I found a process to "jump" the OBD2 ecu's to where you can advance/retard the timing, but this was done on an OBD2 Teg LS, and I was wondering if there is anything that would prevent you from doing this to an OBD2 H22A4. so if you know if there is a reason that ths wont work post some info, thanks guys.
Old May 20, 2004 | 02:24 PM
BB6-213's Avatar
anyone?
Old May 20, 2004 | 03:09 PM
satan_srv's Avatar
Default Re: Jumping ECU on OBD2 Prelude to advance/retard timing? (BB6-213)
well maybe if you explained the process I might know what the hell you're talking about
Old May 20, 2004 | 03:46 PM
BB6-213's Avatar
Default Re: Jumping ECU on OBD2 Prelude to advance/retard timing? (satan_srv)
It is the exact same process that you use to adjust the timing at the distributer on an OBD1 car, only you have to jump the ecu by, putting a paperclip in the diagnostics connector, and they did this on an OBD2 LS, there is a whole writeup on team-integra.nethttp://www.team-integra.net/se...ID=60, so go on there if you need the whole process. All I need to know, is if there would be any difference in doing this with an h22 or a b18b.
Old May 21, 2004 | 07:22 PM
BB6-213's Avatar
bump for the night
Old May 22, 2004 | 02:37 PM
alphajesse's Avatar
You can jump the ignition module service connector to check base timing on a OBD2 lude, but even if you notch the distributor bracket, you are SOL.
BTW, if you want to link people to an article, copy and paste if the page requires a login.
I doubt anyone here wants to sign up for team integra just to read that.
Old May 23, 2004 | 09:47 AM
redline32's Avatar
you can jump it, but its in a different location then the teg, and stock ecu won't allow big timing changes
Old May 23, 2004 | 06:44 PM
BB6-213's Avatar
i just want to retard the timing like 3 degrees to prevent detonation, would it go -3 degrees?
Old May 23, 2004 | 07:02 PM
junbb1's Avatar
Default Re: (BB6-213)
all i know is that a lot of people say to jump the scs before adjusting timing. but i have adjusted timing on hondas for a long time and also done this on the dyno. i have never jumped the scs connector to do so. it is not nescessary.
Old Jun 10, 2007 | 05:58 PM
THC07's Avatar
Default Re: (junbb1)
sorry to bring this thread back from the dead. i searched with no luck.
I dont understand how this guy is gonna retard timing with his dissy. my h22a4 dissy is not adjustable its fixed and timing is all controled by the ecu.
I need to pull 3 degrees for n2o. How?
Im using a obd2 ecu, the 96 p13.
Anyone know how i can retard timing?
Old Jun 10, 2007 | 06:04 PM
road.head's Avatar
Default Re: (THC07)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THC07 &raquo;</TD></TR><TR><TD CLASS="quote">sorry to bring this thread back from the dead. i searched with no luck.
Anyone know how i can retard timing?</TD></TR></TABLE>
break the knock sensor
Old Jun 10, 2007 | 06:17 PM
THC07's Avatar
Default Re: (road.head)
thats not an option. id rather just hook up the obd1 ecu.
how would that retard timing anyway?
the knock retards... dunno what your getting at???
is there any way to retard? other then cam gears?
Old Jun 11, 2007 | 06:41 AM
NirVTEC's Avatar
Default Re: (THC07)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THC07 &raquo;</TD></TR><TR><TD CLASS="quote">thats not an option. id rather just hook up the obd1 ecu.
is there any way to retard? other then cam gears? </TD></TR></TABLE>
Ignition and Cam Timing are 2 different stories.....
How much nitrous are you going to run?
I was using an MSD DIG6 back in the day to do it...
Im selling 2 of them if youre interested....
Old Jun 11, 2007 | 07:45 AM
THC07's Avatar
Default Re: (:=:NirVTEC:=:)
75 dry shot
Old Jun 11, 2007 | 07:54 AM
NirVTEC's Avatar
Default Re: (THC07)
Get it on the Dyno with 1 step colder plugs and go from there......
i personally don't think timing retard should be required but everyones setups are different. I was running an 80 shot-wet with no timing retard and no detonation. I didn't use the MSD to retard until I started using a 100 shot.
I also suggest starting with a 50 shot so you can learn how to use it, and then you can always upgrade from there. It only takes a couple of minutes to change jets.
You have more fun longer going from a 50 to 60 to 75 shot....
buddy4002
Oct 16, 2006 07:13 AM
Zuerst
Jul 29, 2003 04:43 PM
black_sh
May 23, 2003 05:29 PM
