Hybrid is having troubles...Please look
Old May 20, 2004 | 07:31 AM
3.3.3's Avatar
Default Hybrid is having troubles...Please look
stock jdm b18c in 92eg
alright, first thing, for the last two days, the car is havind difficulties starting up in the morning. it fires up for a second and shuts off. it sound like right before its about to idle, it dies. yesterday it took me about 5 tries to get it started. today about 10.
second, i cant seem to check the codes. i put a a paperclip into the green plug but nothing happens. am i checing the right one? its the green plug right below the glove compartment that hangs down right?
my SRS light is on. i swapped out steering columns over the weekend, put everything back together as it was. i missed one connector, and when i hooked it up, the light turned off. now its just constanly on. fuse? if so, which one is it?
thanks in advance.
Old May 20, 2004 | 08:45 AM
b18cx's Avatar
Default Re: Hybrid is having troubles...Please look (3 3 3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 3 3 3 &raquo;</TD></TR><TR><TD CLASS="quote">stock jdm b18c in 92eg
alright, first thing, for the last two days, the car is havind difficulties starting up in the morning. it fires up for a second and shuts off. it sound like right before its about to idle, it dies. yesterday it took me about 5 tries to get it started. today about 10. </TD></TR></TABLE>
[B][Sounds alot like a bad fuel pump relay. Big grey box bolted right above you hood release. When the car tries to start and dies, smack it with a big wrench. If she fires right up, replace the relay/B]
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">second, i cant seem to check the codes. i put a a paperclip into the green plug but nothing happens. am i checing the right one? its the green plug right below the glove compartment that hangs down right?</TD></TR></TABLE>
Going to be a blue 2wire plug. Will have a green rubber cover[/quote]
Old May 20, 2004 | 08:49 AM
3.3.3's Avatar
Default Re: Hybrid is having troubles...Please look (b18cx)
thanks a lot...ill give it a try.
anyone w/ any ideas on the SRS bs.....?
gemineye716
Aug 15, 2008 06:40 PM
_gurusan_
Nov 29, 2007 02:32 PM
h22-hatch
Jul 16, 2007 10:09 PM
NZDelsoldude
Jan 25, 2007 08:51 PM
NZDelsoldude
16
Jan 15, 2007 04:04 PM
