still grinding gears and have no idea why! all b16a gurus please help
Old May 20, 2004 | 06:59 AM
iridebiketrials's Avatar
Default still grinding gears and have no idea why! all b16a gurus please help
when shifting from 1 to 2nd its fine. but from second to third and sometimes from 3rd to fourth it grinds. i have 5 possibilities but need help ruling them out.
1.) shifter bushings/shift linkage-it doesnt seem too tight and im sure they werent repaced ever or ajusted
2.) Tranny is somehow messed up. I have no idea how but maybe. it was perfect like 2-3 months ago. started grinding when i put royal purple synchromesh in there.
3.)clutch is somehow messed up...maybe the fingers are bent or broken. any way to tell?
4.) clutch pedal is somehow bent or warped. thats what the honda dude suggested maybe.
5.)clutch cable. this is what i believe it to be. it is completeely ajusted to the very bottom; no more ajustment is available. if i have a b16a in there then what cable do i use? one from an integra or a crx?
if you guys can in any way help me id be very appreciative.
thanks.
Old May 20, 2004 | 07:10 AM
virginia_dude's Avatar
Default Re: still grinding gears and have no idea why! all b16a gurus please help (iridebiketrials)
If you can engage clutch and go fron neutral to 1st with motor running and car sitting still, your clutch, cable and pedal are fine. And from neutral to any of the 5 gears.
your syncros may have gone bye-bye.
FourthGenHatch's Avatar
Your synchros are probably shot to hell. Try draining the tranny and just put in Honda MTF and see if that helps.
Old May 20, 2004 | 07:17 AM
any other ways to tell?
Old May 20, 2004 | 07:21 AM
Default Re: (iridebiketrials)
with car running but sitting still being able to go from Neutral to any gear says clutch is disengaing and you have no bent shift forks. if it does it driving you got hosed Syncros.
Old May 20, 2004 | 07:55 AM
LSVTEC 91 Civic's Avatar
Banned
Default Re: (virginia_dude)
Double clutch into the gears that grind while you're driving, if double clutching takes grinds away, its a synchro.
Old May 20, 2004 | 07:56 AM
Dave421's Avatar
Drain the fluid and look to see if you see any metal in it. Refill with Honda MTF. Are you sure you put enough in last time? The only reason I can see it starting when changing fluid is if you didn't fill it all the way.
Old May 20, 2004 | 08:02 AM
Harry_Randal's Avatar
Default Re: still grinding gears and have no idea why! all b16a gurus please help (virginia_dude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by virginia_dude &raquo;</TD></TR><TR><TD CLASS="quote">
your syncros may have gone bye-bye.</TD></TR></TABLE>
The notorious reason for Honda trannies to grind
Old May 20, 2004 | 03:53 PM
Jurassic Four's Avatar
From: Where you cant steal it, Maryland, United States
Default Re: (LSVTEC 91 Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic &raquo;</TD></TR><TR><TD CLASS="quote">Double clutch into the gears that grind while you're driving, if double clutching takes grinds away, its a synchro.</TD></TR></TABLE>
Just a stupid question... but what is double clutching? Because my tranny grinds third also... but only when i shift above like 4000 rpm.
Old May 20, 2004 | 03:59 PM
Banned
Default Re: (Jurassic Four)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jurassic Four &raquo;</TD></TR><TR><TD CLASS="quote">
Just a stupid question... but what is double clutching? Because my tranny grinds third also... but only when i shift above like 4000 rpm.</TD></TR></TABLE>
GM Synchromesh will solve your problem... Do a search on it.
Double clutching is a method used with non synchronized transmissions. Shift from 2nd into N, let clutch out. Push clutch in, go into 3rd... You just doubleclutched from 2nd to 3rd. In my case, my 3rd gear synchro is dead so this is the method I use to shift so I don't destroy anything else.
spoonhbk11
Dec 26, 2009 12:35 AM
crxsteve
Jun 13, 2007 04:47 AM
LankorDie
12
Jul 26, 2006 06:45 PM
jdmef9b16a
Jul 11, 2006 03:37 PM
JediPimpCrx
Oct 23, 2002 06:44 PM
