Building a street motor for 300whp
Old May 20, 2004 | 12:54 AM
typeRmini's Avatar
Default Building a street motor for 300whp
Ive got a JDM B18c motor at the moment.
I am aiming to build a motor to run around 300whp. The question is do i use my B18c or do I get another block and get that built to take the extra strain of boosting?
Also what sort of spec should i go for?
Thanks Tony
Old May 20, 2004 | 01:05 AM
Adi Radoncic's Avatar
On Fire!
Default Re: Building a street motor for 300whp (typeRmini)
I know I'm not really answering your question on what to do to build your motor but, with a nice turbo kit and that stock b18c 300whp is not a problem.
There are plenty of people on this board that have achieved that goal and driving their cars on the stock blocks for quite some time now.
Old May 20, 2004 | 02:29 AM
ndogg's Avatar
Default Re: Building a street motor for 300whp (adigsr)
werd. see sig.
Old May 20, 2004 | 04:12 AM
FOrSfEd's Avatar
Default Re: Building a street motor for 300whp (ndogg)
Yeah I would keep it stock unless you have the funds to build it, but I would def keep the motor.
Old May 20, 2004 | 04:48 AM
swlabhot's Avatar
If you have the funds now and you are planning on running high boost in the future than I'd say build it now and get it over and done with, else you'll be OK on stock. I've been running on stock for over a year now and its going in for a full rebuild soon.
Old May 20, 2004 | 09:01 AM
typeRmini's Avatar
Default Re: Building a street motor for 300whp (swlabhot)
ok, so if i stick with my stock B18c is there anything that i should upgrade,
ie the head gasket, head bolts etc?
cheers Tony
Old May 20, 2004 | 09:04 AM
FOrSfEd's Avatar
Stock motor should be good for 300. I would def good a hella good fuel set up though
Old May 20, 2004 | 09:07 AM
typeRmini's Avatar
Default Re: Building a street motor for 300whp (FOrSfEd)
At the moment i am running on DTA fully mappable ecu, this should be fine for setup.
one other thing, at the moment i am using ITBs. What sort of inlet manifolds would suit a boosted engine?
Tony
Old May 20, 2004 | 09:19 AM
CRX T-Si's Avatar
I have not seen any Honda make a closed chamber on the ITB's for boost. That would be a good idea, have someone make an enclosed chamber that connects the ITB's and use it for boost.
The Nissan Sunny uses it and that **** runs.
Also I would stay stock to save money for now and build motor later. After all 300 for the B18c is no problem, but tunning is the key.
Old May 20, 2004 | 09:28 AM
TurboJesse
Guest
Posts: n/a
Default Re: Building a street motor for 300whp (CRX T-Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX T-Si &raquo;</TD></TR><TR><TD CLASS="quote">I have not seen any Honda make a closed chamber on the ITB's for boost. That would be a good idea, have someone make an enclosed chamber that connects the ITB's and use it for boost.
Also I would stay stock to save money for now and build motor later. After all 300 for the B18c is no problem, but tunning is the key.</TD></TR></TABLE>
all the cars that run ITB's with boost are MAF cars.
kcvi3tstyl3
Dec 4, 2009 09:30 PM
civicsit
Oct 22, 2004 07:04 AM
b16civic91
Oct 1, 2003 06:55 PM
thehatchninja
Jun 17, 2003 07:37 AM
wuhungsixxx
16
Aug 3, 2001 12:02 PM
