ABS Going out, I think?
Old May 19, 2004 | 11:20 PM
AXAIntegra's Avatar
Default ABS Going out, I think?
I just pick up a 92 Integra GS. It's in great shape except the ABS system going a rye. When I break, I feel a strong push and jerk at the very last second before I stop, every time I stop. The ABS light is not on though. The puzzling thing is that when it does come on the car stops fine.
What could it be and about how much would it cost to fix?
Second problem,
When I shift from park into drive the shift handle is very difficult to move and properly get into gear. But once in gear the trans shifts fine.
Is this a problem with the shifting handle or major trans problem. The car is an automatic.
Tony
Old May 20, 2004 | 05:46 AM
rgbintx's Avatar
Default Re: ABS Going out, I think? (AXAIntegra)
As for the problem with your shifter, it sounds like a linkage problem. Check under the car while somebody is shifting to see if it is binding anywhere on the outside of the tranny. It may be hitting your exhaust or something.
tban21
Audio / Security / Video
May 21, 2009 01:24 AM
LSracing94
Aug 29, 2005 06:23 PM
dynamo
May 29, 2004 09:32 PM
