Would someone review my boost rom please?
Old May 19, 2004 | 09:43 PM
T-RO's Avatar
Default Would someone review my boost rom please?
Well if you have time or are bored would you check this out? I'm gonna be putting my kit on in 2 weeks and this was the rom I was planning on using. I dont have access to a wideband yet unfortunatly so i'm planing on tuning the best I can until then. I just dont want to go to crazy on it and blow my **** up. lol
Heres the info:
Built on Crome ver 9.1
94 Civic EX
Stock D16z6
460cc RX7 injectors
2G DSM T25 turbo
Running stock boost (around 8psi)
HF Manifold/adapter
2" charge piping
JRC 5" FMIC
1g DSM BOV
2.5" downpipe
stock exhaust system (will be changed later to 2.25")
This is a copy of my "Notes" on what I did to the ROM:
CROME 0.9.1
CR_0.9.1_006
5-20-04
JDM P30 (203) Based Code
Imported fuel/ignition values (USDM P28 304)
Scaled for 460cc Injectors
Disable Knock sensor
Enable Atmospheric pressure
7500 Rev limit
Enable Vtec 4800
Speed limiter 158mph
Cold Idle 750rpm
Warm Idle 750rpm
Moving Idle 810rpm
Fuel values adjusted (multiplier in Crome did not give me accurate #'s)
Hondata fuel adjustments made (discussed in another thread)
Boosted
115% average efficiency
Ignition retarded (step retarded)
Column 9-B12 .25 deg ret
B13-B14 .50 deg ret
B15-B16 .75 deg ret
Checksum removed
Heres a link to the .bin: http://www.pgmfi.org/phorum/do...6.bin
Thanks for your time guys
Old May 20, 2004 | 03:50 PM
T-RO's Avatar
Old May 22, 2004 | 07:42 AM
T-RO's Avatar
guess nobody is interested lol
no problem
angela_itr
Oct 31, 2005 10:49 PM
GWInquisitor14
Jun 5, 2005 12:06 PM
Jared
Jun 5, 2003 06:30 PM
rob1208lv
Feb 5, 2002 10:46 AM
GSRwBOOST
Dec 18, 2001 08:32 PM
