anyone install the Center CROSSMEMBER? (rack n' pinon)
Old May 19, 2004 | 09:11 PM
patastinky's Avatar
Default anyone install the Center CROSSMEMBER? (rack n' pinon)
*edit* its on my 4th gen 92 accord ex
sup! basically my question is this, how do i get to the bolt that is holding the steering rod from teh crossmember. There are (4) bolts that hold the crossmember in, then i have to unbolt the rear motor mount from the engine, and disconnect the tie rods. I got all that no problem..
But how do i to the bolt that is w/ in the boot in/on the firewall? It's easy when the motor is out!! ( took the crossmember out of a junked accord w/ no motor)
But i know there's gotta be a way to install it w/ out removing the Engine!!
Anyone please help, i do everything myself and i would hate to get this done at a shop when i know i can do it myself just having a tough time figureing out how to get at that bolt!
LuiS
Modified by patastinky at 10:34 PM 5/19/2004
Old May 19, 2004 | 09:35 PM
patastinky's Avatar
Default Re: anyone install the Center CROSSMEMBER? (patastinky)
nevermind, i found out that i have to unbolt the steering colum, pull up the rug and open up the black boot under the carpret to get to the bolt
Momentum
10
Aug 11, 2010 10:13 PM
Burlyirishdude
Sep 22, 2005 06:33 PM
RACEPAK
Jun 17, 2004 12:50 PM
