Latest dyno of the old motor-open header.
Old May 19, 2004 | 08:59 PM
b19coupe's Avatar
Default Latest dyno of the old motor-open header.
Getting ready for Pomona, hit the dyno for some fine tuning of the A/F with a straight pipe bolted to the header. No muffler, no cat.
Here is the motor through the muffler:
Shawn tried to print the final tuned run from tonight and the graph from the car when it was running through the muffler, but his printer was not cooperating. Superimposed, there are some nice gains 6,000-8,000 running open header. Lost ~3 peak hp, but the mid-range more than makes up for it
Old May 19, 2004 | 09:03 PM
Turbo R's Avatar
Default Re: Latest dyno of the old motor-open header. (b19coupe)
what are your basic mods?
nice numbers by the way
Old May 19, 2004 | 09:06 PM
b19coupe's Avatar
Default Re: Latest dyno of the old motor-open header. (Turbo R)
GSR block/crank. 85mm IB "Super Dupers", Portflow ported, Alaniz welded combustion chamber B16 head, Toda 'D' cams, Hondata.
Old May 19, 2004 | 09:08 PM
Turbo R's Avatar
Its says "Old motor"
why are you building another?
Old May 19, 2004 | 09:09 PM
b19coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo R &raquo;</TD></TR><TR><TD CLASS="quote">Its says "Old motor"
why are you building another?</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=686399
Old May 19, 2004 | 09:15 PM
Turbo R's Avatar
Old May 19, 2004 | 09:25 PM
smnowell's Avatar
Must be nice having just about 260whp....what a bitch Let us know how you do this race season.
Old May 19, 2004 | 10:19 PM
98itR484's Avatar
Default Re: Latest dyno of the old motor-open header. (b16a ferio)
u just never give up huh Todd
Those are some very nice numbers, cant wait to see what the new one will do
We gotta plan something out get together again, throw back a few beers or something
-Arno
Old May 19, 2004 | 10:37 PM
b19coupe's Avatar
Default Re: Latest dyno of the old motor-open header. (98itR484)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98itR484 &raquo;</TD></TR><TR><TD CLASS="quote">We gotta plan something out get together again, throw back a few beers or something
-Arno</TD></TR></TABLE>
Sounds good to me
Old May 20, 2004 | 06:06 AM
IN VTEC's Avatar
Did you play with the pipe length at all?
Old May 20, 2004 | 06:20 AM
b19coupe's Avatar
Default Re: Latest dyno of the old motor-open header. (IN VTEC)
No. Not enough time or the availability of different lengths.
Old May 20, 2004 | 07:10 AM
TodaSi's Avatar
Wow, all I can say is STRONG, yep, strong is what you have there
Have fun at Pomona.
Old May 20, 2004 | 07:26 AM
TEAM562racing's Avatar
hey todd,
we will be out there to hang out and check things out...
from what i know they are charging $10 to watch .
this one is yours for the taking buddy you got our support.
see you there.
Old May 20, 2004 | 10:34 AM
b19coupe's Avatar
Default Re: Latest dyno of the old motor-open header. (EGbrknuoff)
Thanks Chad. Thanks Ryan-see you guys there.
Old May 20, 2004 | 01:50 PM
Tbone's Avatar
Looking good I cant keep up with you man..lol
Old May 20, 2004 | 03:08 PM
JDM2ndGen's Avatar
Default Re: Latest dyno of the old motor-open header. (Tbone)
nice numbers ...
Old May 20, 2004 | 04:27 PM
b19coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tbone &raquo;</TD></TR><TR><TD CLASS="quote">I cant keep up with you man..lol</TD></TR></TABLE>
I believe that it is I who can't keep up with you, Mr. 11's
Old May 21, 2004 | 03:26 PM
smokey2.0's Avatar
looking good todd, good luck in pomona. keep us posted, i would like to see what #'s you hit
Old May 24, 2004 | 09:30 AM
TodaSi's Avatar
Default Re: Latest dyno of the old motor-open header. (smokey2.0)
So, what did you run at Pomona?
Old May 24, 2004 | 10:53 AM
MiKE 76...
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">GSR block/crank. 85mm IB "Super Dupers", Portflow ported, Alaniz welded combustion chamber B16 head, Toda 'D' cams, Hondata.</TD></TR></TABLE>
Long rod or raised pin?
Or all shelf products?
Old May 24, 2004 | 12:09 PM
TodaSi's Avatar
Default Re: Latest dyno of the old motor-open header. (MiKE 76...)
I believe they are 'off the shelf' pistons.
Old May 24, 2004 | 06:22 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
hahah thats my old P72 head on there......DAMNNNNNN
Modified by SnoFlake EG at 7:50 PM 5/24/2004
Old May 24, 2004 | 06:32 PM
boosted92's Avatar
Default Re: Latest dyno of the old motor-open header. (SnoFlake EG)
Whats the CR of that motor?
Old May 25, 2004 | 01:48 PM
b19coupe's Avatar
Default Re: Latest dyno of the old motor-open header. (TodaSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TodaSi &raquo;</TD></TR><TR><TD CLASS="quote">So, what did you run at Pomona?</TD></TR></TABLE>
Ran a best of 12.3 @111.99.
Compression ratio is about 13.6:1.
Not your head, Snowflake, that head has not come back from Brad yet.
Off the shelf IB spec Wiseco pistons and Crower rods, stock GSR crank.
Old May 25, 2004 | 04:35 PM
Tbone's Avatar
Whats the weight ? What were your 60's. good job man
