what CRX engine did i buy
Old May 19, 2004 | 06:01 PM
jdwebmaster's Avatar
Default what CRX engine did i buy
I just picked up a 16valve CRX enigine off this guy but i have some questions. The date on the engine is 91 when the guy thought it was a 89. Its running Dual point fuel injection. And its 16 valves. Was there a SI out there that ran this or has this engine been modified. Its has 180,000 miles on it but im only interested in the Tranny but would also like to put the 16valve head on my HF engine would this be possible? The engine looks great besides the normal dirt.
Old May 19, 2004 | 06:06 PM
wpgcivic's Avatar
by the sounds of things you got yourself a d15b2
Old May 19, 2004 | 06:18 PM
wpgcivic's Avatar
if it was to be si then it would be multi point fuel injection which would be d16a6 but in this case you got yourself a dx
Old May 19, 2004 | 06:20 PM
I3ackfire's Avatar
Default Re: (wpgcivic)
Ya D15b2.
You can swap heads, and swap to MPFI, there are literally hundreds of post about them in the archives!
Just use the search feature at the top of the page
Old May 19, 2004 | 06:22 PM
wpgcivic's Avatar
just wondering do si's drop into hf's? are hf's mpfi?
Old May 19, 2004 | 06:23 PM
wpgcivic's Avatar
never mind
here is a good site
http://www.integra.orcon.net.nz/engines
Old May 19, 2004 | 08:51 PM
EG8R's Avatar
Default Re: (I3ackfire)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I3ackfire &raquo;</TD></TR><TR><TD CLASS="quote">Ya D15b2.
Just use the search feature at the top of the page </TD></TR></TABLE>
HF is MPFI. And no the head won't work. The HF engine does not have valve reliefs for 16 valves.
Old May 20, 2004 | 01:12 AM
Default Re: (skelly ed666)
is there a way to get the pistons to have more valve relief. I thought there was enough clearance in the back valves to not have a releif. I know a machine shop that can make them if needed but is it worth it
Old May 20, 2004 | 03:12 AM
civickiller's Avatar
Default Re: (jdwebmaster)
dont gotta jump to the conclusion that its a b2 just because it has a dpfi, it could easily be a a6 with a dpfi
Old May 20, 2004 | 03:16 AM
Default Re: (civickiller)
well i checks the motor stamp its a d15b2
Old May 20, 2004 | 05:29 AM
wpgcivic's Avatar
yeah man like i told you from my beliefs but dont quote me a si will drop right in with minimal mods, find a si for a couple bills and drop that in
Old May 20, 2004 | 05:58 AM
blah13's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skelly ed666 &raquo;</TD></TR><TR><TD CLASS="quote">
HF is MPFI. And no the head won't work. The HF engine does not have valve reliefs for 16 valves.</TD></TR></TABLE>
Someone on here put the a6 head on the HF block and clayed the motor and it worked. I believe the reliefs are just in case you jump timing, I'd have to search for the thread.
Old May 22, 2004 | 02:07 AM
Default Re: (blah13)
thanks for all the info but still a little confusing. one guy says this then another. is there anybody else that might know anything. im just looking for a cheap mini me swap. Also if i where to try something like do i need the ECU or would the stock one work with the 16 valves?
Old May 22, 2004 | 02:50 PM
G1 TEGGY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wpgcivic &raquo;</TD></TR><TR><TD CLASS="quote">never mind
here is a good site
http://www.integra.orcon.net.nz/engines</TD></TR></TABLE>
that guy's list is completely wack yo
Old May 22, 2004 | 03:09 PM
Malgerus's Avatar
Default Re: (G1_TEGGY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G1_TEGGY &raquo;</TD></TR><TR><TD CLASS="quote">
that guy's list is completely wack yo </TD></TR></TABLE>
Agreed. 1st Gen B16's are the exact same hp.
Old May 23, 2004 | 08:24 AM
wpgcivic's Avatar
i know its not 100% but at least it gives an idea of roughly what is out there
Old May 23, 2004 | 09:23 AM
Bunger's Avatar
Default Re: (Mr. S)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. S &raquo;</TD></TR><TR><TD CLASS="quote">
Agreed. 1st Gen B16's are the exact same hp.</TD></TR></TABLE>
That list may be accurate, keep in mind that 1st gen b16a's had the weakest cams and a 58mm TB. And don't forget that it matters if the motor is JDM or USDM, manual or auto.
Old May 23, 2004 | 09:31 AM
OptimusPrimeX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civickiller &raquo;</TD></TR><TR><TD CLASS="quote">dont gotta jump to the conclusion that its a b2 just because it has a dpfi, it could easily be a a6 with a dpfi</TD></TR></TABLE>
lol.. i hope that was sarcastic..
Old May 23, 2004 | 02:49 PM
wpgcivic's Avatar
yeah why would someone convert a mpfi car to dpfi?
Old May 27, 2004 | 01:25 PM
G1 TEGGY's Avatar
Default Re: (Bunger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bunger &raquo;</TD></TR><TR><TD CLASS="quote">
That list may be accurate, keep in mind that 1st gen b16a's had the weakest cams and a 58mm TB. And don't forget that it matters if the motor is JDM or USDM, manual or auto.</TD></TR></TABLE>
I'm quite sure a "92-95 Civic" does not have 160hp and a lot of the integra engine codes are off, that's what caught my attention first
Old May 27, 2004 | 01:47 PM
4drEF's Avatar
Keyboard Humorist
Ya D15b2.
QUOTE
&raquo;
[QUOTE=skelly ed666]
Who's talking about Hf's? An HF is a D15B6 not a B2.
B2 is DX/Lx motor.... 16 valve.
Anyway, HEY - since you were able to locate the DATE on the engine, why not look again for the ENGINE code???
Old May 27, 2004 | 01:58 PM
slowpokesi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdwebmaster &raquo;</TD></TR><TR><TD CLASS="quote">thanks for all the info but still a little confusing. one guy says this then another. is there anybody else that might know anything. im just looking for a cheap mini me swap. Also if i where to try something like do i need the ECU or would the stock one work with the 16 valves?</TD></TR></TABLE>
if you have the motor why cant you go and look at the engine stamp and tell us what it is. D15b2 is a dx motor, it is the only motor that came with a dpfi setup, nobody in there right mind would convert a d16a6 to dpfi.
You can put the head on to your crx, but you will need to swap out pistons, if your going to go that far why not install the d15b2 motor in your car, and convert it to mpfi using the parts off your hf.
Old May 27, 2004 | 02:11 PM
4drEF's Avatar
Keyboard Humorist
Default Re: (slowpokesi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowpokesi &raquo;</TD></TR><TR><TD CLASS="quote">
... if your going to go that far why not install the d15b2 motor in your car, and convert it to mpfi using the parts off your hf.</TD></TR></TABLE>
Don't do that. It will be slower than the D15B2. The HF intake is VERY restrictive.
Old May 27, 2004 | 02:13 PM
slowpokesi's Avatar
Default Re: (4drEF)
err, well fine then, get a si manifold, its not like they could cost more than 50 bucks, hell i sold a b16a manifold for like 35
dww0708
Jan 9, 2011 08:33 AM
xerowatts
May 13, 2008 07:16 AM
g_tech9
Classic Hondas
Aug 8, 2007 06:44 AM
YoungSakamoto
14
Nov 17, 2005 01:40 PM
m3talc0re
Mar 24, 2005 01:46 PM
