JUST MAKING SURE THERE IS NO DAMAGE?
Old May 19, 2004 | 02:15 PM
fastest's Avatar
Default JUST MAKING SURE THERE IS NO DAMAGE?
JSUT WAS WONDERING MY BUDDY HIT THE BOTTOM OF MY OIL PAN ON THIS CEMENT PEICE BC ITS SITTING LOWER THEN USUAL ...IN ANY CASE IT DENTED IT A BIT AT THE FRONT AND SCRAPED THE HEADER THERE ARE NO LEAKS FORM THE OIL PAN OR ANYTHGIN BUT SHOULD I REPLACE IT AND DO THEY SELL AFTER MARKET LIGHT ONES OR SMALLER ONES?
Old May 19, 2004 | 02:22 PM
DragII's Avatar
25 Year Member
Default Re: JUST MAKING SURE THERE IS NO DAMAGE? (fastest)
I think your keyboard is broken, your caps lock appears to be stuck.
Old May 19, 2004 | 02:36 PM
Ekasey's Avatar
Default Re: JUST MAKING SURE THERE IS NO DAMAGE? (DragII)
depends how big the dent is it will force the oil to the outisdes of the pan and may cavitate the oil cump under hard driving. what do you mean lighter the stock pan weighs nothing but z10 make an aluminum piece that is really nice
Old May 19, 2004 | 07:54 PM
fastest's Avatar
Default Re: JUST MAKING SURE THERE IS NO DAMAGE? (eLusive ek4)
thanks dude....nah its not that bad i guess just th efront across the front of the oil pan is a lil 1 cm not even in across...thye make aluminum pans that would be sick
Old May 19, 2004 | 08:06 PM
Kal's Avatar
Kal
yes they make aluminum oil pans. if the dent is too deep it might cause VTEC not to occur if you have it.
Old May 19, 2004 | 08:20 PM
civickiller's Avatar
Default Re: JUST MAKING SURE THERE IS NO DAMAGE? (Kal)
this happened to an ls motor i bought, got smashed and it was smashed enough where it went right up against the oil pickup so the motor wasnt getting any oil so it burned up the whole motor. it would be better to make sure
miataguy
11
Feb 20, 2007 05:00 PM
thegeorge613
Jul 31, 2006 05:02 PM
Andrewm224
Jul 16, 2005 08:08 PM
civickiller
May 17, 2003 08:35 AM
