A lot of white smoke when starting the car
Old May 19, 2004 | 12:41 PM
brian2903's Avatar
Default A lot of white smoke when starting the car
Why?
Please help, thanks.
Old May 19, 2004 | 02:37 PM
Ekasey's Avatar
Default Re: A lot of white smoke when starting the car (brian2903)
smell it taste it
Old May 19, 2004 | 07:01 PM
brian2903's Avatar
oilly smell
Old May 19, 2004 | 07:07 PM
SpeedDreamz.com's Avatar
valve stem seals leak
Old May 19, 2004 | 08:22 PM
brian2903's Avatar
how to fix it?
civickiller's Avatar
Default Re: A lot of white smoke when starting the car (30psiCiv)
he probably doesnt know waht hes talking about. so theres white smoke when you start up your car, is it just when you start up your car from an overnight sit, or still does it after you driven the car for an hour and then start it up agains ?
Old May 20, 2004 | 04:29 AM
BB2H23A1
Guest
Posts: n/a
Default Re: A lot of white smoke when starting the car (civickiller)
condensattion if it goes away if not you might have a bad head gasket white smoke could be coolant
Old May 20, 2004 | 04:42 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civickiller &raquo;</TD></TR><TR><TD CLASS="quote">he probably doesnt know waht hes talking about. so theres white smoke when you start up your car, is it just when you start up your car from an overnight sit, or still does it after you driven the car for an hour and then start it up agains ?</TD></TR></TABLE>
Ok, so what is your suggestion? TO give an accurate answer we would need to know a little about your setup. White smoke when you start it up would have to be burnoff from some type of leak into the cylinders. Nothing else would be hot enough to generate smoke. Based on the color and smell of the smoke tells you what is leaking.
Old May 20, 2004 | 06:10 AM
brian2903's Avatar
Thanks guys!!
Ok, the white smoke comes out every time when I start up the car, and it goes away while driving. However, no matter how long do I drive, the white smoke comes out everytime I restart my car.
Old May 20, 2004 | 07:40 AM
b18cx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 30psiCiv &raquo;</TD></TR><TR><TD CLASS="quote">
Ok, so what is your suggestion? TO give an accurate answer we would need to know a little about your setup. White smoke when you start it up would have to be burnoff from some type of leak into the cylinders. Nothing else would be hot enough to generate smoke. Based on the color and smell of the smoke tells you what is leaking.</TD></TR></TABLE>
What he said.
Valve stem seals sound worn out. Will most likely have to pull the head to pull the valves out and then replace the seals. Not a fun task.
Old May 20, 2004 | 11:19 AM
brian2903's Avatar
How much usually cost to fix it?
Old May 20, 2004 | 04:32 PM
The seals are really cheap, about $1.50-2.00 each. It will cost you about $200 labor to do if you let someone do it start to finish.
thedon360
Jul 16, 2013 08:34 AM
dailyekhatch
Aug 15, 2011 06:45 AM
Inf^Shini
Oct 30, 2007 09:27 PM
Cyber ITR
Feb 1, 2007 12:36 AM
HBK_DAVIDDD
Jul 28, 2005 11:07 PM
